gizlaroc said:
Oh, and the panel says 50.1 under the signal menu. Now I know the Faroudja chipset is out slightly and I think the Panny is out by .05 too, so try 50.05 and then time how long between the dropped frames, then try 50.06 and see if it is getting longer or shorter, keep doing this till it is spot on.
yeah , its between 50.04 and 50.05 and almost no framedrops for half an hour,
pans are smooth as silk and with 1:1
[email protected] it seems I can live with vga .
resolution with the nVidiacard is almost linear up to 5,8 MHz ! , some minor irregularities appear beyond 6 MHz.
what strikes me really is the quality of the PHD 8 deinterlacer , will have a look for a 576i player for additional tests.
made a break-in dvd without menu and a replay function ..so there are 68 h on the panel a.t.m.
I think I wlll try to calibrate it @ 100h .
like it very much the new PHD 8 - 50MBit footage from a DVCpro professional camcorder never looked better
regards from the black forest
mine
