Black out material - where from!?
Discussion in 'Projectors, Screens & Video Processors' started by Feersum enjinn, Jul 29, 2002.
  1. Feersum enjinn
    Feersum enjinn
    Ive been to two furnishing/material shops and neither had any.
    And i am in North london.
    Any ideas where i can get some? and/or is teher a site perhaps where i can just buy some online.
    Any help appreciated -
    Regards
  2. mcmullanbrush
    mcmullanbrush
    Apr 20, 2002
    1,137
    39
    rotherham
    I got some from the Dunelm shop.
    I have no idea how widespread their shops are though.
    Tou can get it in pre cut standard curtain sizes or cut to your exact requirements
  3. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Got mine from a market stall - there's usually a fabric stall on most markets. First chap I tried hadn't got any that week, but would have the next - the next chap (different market) had it - £3.50 per metre, 54" wide.
  4. Hex
    Hex
    May 14, 2002
    56
    9
    Worcester
    try a curtain shop!
    Hex
  5. graham.myers
    graham.myers
    I actually got mine from a roller blind company. They made me a black out roller blind. I just need some velcro strips down the side now as there is still some leakage.
  6. pgd
    pgd
    Feb 20, 2002
    15
    Graham
    Can you provide details of the blind size (LxWxH) and the price?
    PGD
  7. graham.myers
    graham.myers
    it was a custom fit for the window in my HC room.
    I can't remember the price, I'll ring 'er indoors and see if she can remember
  8. Guest
    I bought blackout lining for curtains from a shop called Knightingales (they are something to do with the Roseby's chain). Fairly expensive (about £30 per pair) but then our windows are about seven feet wide and have a six foot drop. They work well but I still have to fit some velcro so they stick to the edge of the windows (there is still a lot of light leakage around the edges).
  9. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,107
    63
    +115
    I got mine from a Knightingales in Derby, but took it back because the piece i need was 7ft x 4ft and a curtain this big was 2 pieces put together and u could clearly see the join
  10. graham.myers
    graham.myers
    I've had a chat with the wife. We got an all in deal from the roller blind people and that particular window was not priced seperatly - he "did a deal" cos we got something like 8 windows plus a conservatory done at the same time.
  11. pgd
    pgd
    Feb 20, 2002
    15
    Thanks for this, I'll put it on my list of things to do, along with ceiling mounts. ;-)
    PGD
  12. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,634
    UK.
    +3,132
    You should be able to get it from most curtain shops/haberdashers (sp?), and I got mine from Alders.
    Gary.
