Probably the same way you can be laying on the floor yet be standing in the door of a helicopter shooting a gun...How the hell are they able to carry on controlling from the grave?
Probably the same way you can be laying on the floor yet be standing in the door of a helicopter shooting a gun...![]()
Blackbird is an awesome perk, great new addition IMO.
Does it show Ghost players aswell?
Jon, you should try 8/9/11, but with dogs. So when the enermy team think they can hide in buildings from the CG the dogs can hunt them out, I'm goning to try this out tonight![]()
I think it shows all players but dont quote me on that. Im sure Tp or stevie can confirm.
I have used the dogs before but I found I got more kills from the gunship. If you get a map with an open spawn such as Grid you can get loads of kills. Think I saved a video last night on Grid, check it out if you get time![]()
"Ghost is a Tier 1 Perk in Call of Duty: Black Ops. It makes the user undetectable by enemy Spy Planes and SR-71 Blackbirds. Ghost Pro makes the user undetectable to enemy aircraft, sentry guns, and infrared devices such as the Infrared Scope and Camera Spike. Ghost gives the user a ghillie suit on certain maps"
I have hardline so I do it in 2 (on most classes).I always go with RC as I just don't get the spy plane. I don't understand how people use it to their benefit (I understand the principle just not the practice). For me it takes all of my time watching the game screen for enemies without having to keep checking the mini-map.
Any tips on how to use them (as I would like to improve)?
It helps immensely to get to higher killstreaks. Yah you have to check your minimap often but you should be doing that regardless of if a spy plane is up.
After you earn it, don't round any corners just yet if you're new to the principal. Call it in, wait a second for the red pings to show up on your map. Try to anticipate where they are headed based on their location (for instance, if it shows them in a corridor with only two paths of travel then you know where you can find them) and go kill them, and alternatively, you can watch your flank so you won't be killed from behind.
Think of it as your rear view mirror (if you drive) and constantly keep checking it for any baddies.
I am still undecided on which k/s to rock.
Was using 3/5/9 the other day, and from 4 times with the Chopper Gunner it only did'nt get shot down once. So the other 3 times I probably only got about 3/4 kills between 3 CG's. When it it doesnt get shot I get around 8-15 kills depending on map.
Tried the Napalm, and if you put it on the right spot it can net you a few kills, other times I get zero.
Mortar Strike has hardly got me any kills.
I miss my Harrier
Also, I hate Care Packages, it seems way to generous to give the higher k/s.
