Black Material to temporary transform screen from 16:9 to letterbox
Discussion in 'Projectors, Screens & Video Processors' started by dek11677, Aug 2, 2012.
  1. dek11677
    dek11677
    Jun 19, 2012
    28
    3
    Hey guys,
    I'm looking for black material so I can cover the top and bottom of the screen when watching in letterbox ratio, so obviously I'm not looking for a permanent adhesive backed material just something I can attach by velcro when the movie is in the 2.40:1 aspect ratio.
    Any suggestions would be greatly appreciated.
    Dek
  2. True Romance
    True Romance
    Feb 7, 2005
    6,965
    Wolverhampton
    +3,031
    "Devore" is by far the best, you can buy it by the metre. May be stick it to some panels which you can then put in place when needed.
    link
  3. dek11677
    dek11677
    Jun 19, 2012
    28
    3
  4. True Romance
    True Romance
    Feb 7, 2005
    6,965
    Wolverhampton
    +3,031
    Trust me get the devore, looks like its the same price or cheaper than the one you linked to.
  5. barry7767
    barry7767
    Sep 19, 2007
    575
    +416
    Has anyone made any removable masks for a Carada screen? Worried that with the thickness of the screens frame there may be a gap between masks and screen material leading to shadows. Unless of course there is a clever way of eliminating the gaps?
  6. True Romance
    True Romance
    Feb 7, 2005
    6,965
    Wolverhampton
    +3,031
    I have small gaps (6mm+-) on my diy masking and it doesn't cause any issues with shadows and the like.
  7. KelvinS1965
    KelvinS1965
    Jan 3, 2006
    17,077
    +8,026
    I used some velvet as temporary side masks and they hung some distance away from the screen (maybe 3-4") and it still looked better than seeing the uncovered screen.
    One trick worth mentioning is to shift the 2.35:1 image down to the bottom of your screen then you only need a top mask. Or if you have an electric screen, don't lower it all the way so that the image is masked by the bottom border and a single top mask.
