Black levels on Pio 50HDE
Discussion in 'Plasma TVs Forum' started by Yid219, Jul 6, 2004.
  1. Yid219
    Yid219
    Jul 4, 2004
    56
    11
    +7
    i know this may have been talked about before but can anyone who has the 50" please let me know what the black levels are like and if they get better whilst the screen is still "running in" as I am unable to make my mind up as to what screen to go for Pan or Pio?
  2. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    Panasonic has a darker black when the room is dark, but there are many more factors to consider... :)
  3. LeeT
    LeeT
    Mar 24, 2004
    77
    Derby
    Am totally happy with my 504HDE used with my Arcam DV-79 over a wireworld HDMI cable, the PQ is outstanding and Gordon is coming to calibrate now that I have a few hundred hours on the panel so we'll see what difference that makes.
    The SKY+ PQ is just about ok, will try with a better RGB SCART to see if that makes any difference.
    IMHO you have to audition all the panels you want and decided which one based on more than how black it is ;)
    Hope this helps...
    Lee m :D
  4. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,175
    +1,185
    Demoed the 50" HDE, 43" HDE & 42" PHD. The Pioneers I saw were not set-up to a standard I could live with - it wasn't that the blacks didn't go black enough, but that there was a lack of detail between dark objects. Do you need to have speakers and media box with the package? If not, you shuold look at the 50" MXE1. It's more configurable than the HDE, so you'll get better pictures.
    Tough one between that and the Panny. I'd love to see a calibrated version of each, side by side. Ones that aren't set-up to their best just add to the confusion.
