C
carrera2rs
I am experimenting with settings on my new HT200DM, has anyone else had the experience to improve black levels ?
I have the following system :
Toshiba SD900E, Sim2 HT200DM, specially made up high quality component cable, Yamha DSP AX1, energy 5.2's The creen is a matt white Homecreens low gain screen 70" with blacked surround on a 16:9 format
I do find the black detail and black levels ok, but this is where I would like the most improvement.
Any ideas ?
I will be trying to reduce the 'halo' effect from the DLP and have tried Gamma settings / contrast etc. Mayve I simply have to accept this and be satisfied !?
Any ideas ?
Other cables, screen surfaces (Stuart Firehawk too expensive), Views on the DVD player etc would be greatly appreciated (I have yet to try a region 1 disc which should be better as I can then run progressive scan. (The Pal progressive on this machine I do not find particularly good)
Any ideas ?
Any ideas ?
