Black level on Sony KV28LS35 is.........
..driving me mental:mad:
the "movie" setting is too bright, making blacks (like Space scenes in sci-fi films, Alien, etc...) look washed out and snowy.
the "live" setting is too dark, making it hard to see some of the action.
the "personal" is all over the shop, as i have to keep changing it for different DVDs.
all this is happening in RGB mode, which isn't very impressive from a sony at all.:(
any other owners having trouble with this set. and what is a good set-up disc to buy, so i can try and get some "standard" in place?
thanks.:mad: :(
S
shaunthedude
I have the sony px2 rp television. I also find movie setting too bright, live just crappy and have had to set it to personal. I find that in order to get a nice black background I have to have the brightness too low making it too dark on light scenes. I cant win.
shaun
S
smallman28
Best thing I found was to use the THX Optimiser found on some DVD's,Star Wars Episode 1 for example.
There are some that deal with brightness/contrast and I found these a great help in helping to acheive a balance.
I used to notice some solarisation effect on some of the dvds I had that seemed to be caused by these levels being too high and once I had reduced them it disappeared with the added bonus of some finer detail becoming more obvious.
Some of the tests you have to have a special filter for but they are only for the colour settings.
Oh,just noticed you are using RGB and I am only using SVHS so dont know if you can alter brightness/contrast in RGB,can you?
By the way I am also using the KV28LS35.
F
fernando
I am a very happy owner of a KV28LS35 TV set.
I also noted that the pre-adjust image options are horrible but it is possible to solve it. In the movie option you can can move the contrast bar. If you do this 5 times to the left you have, more or less exactly, the adjustment of the THX optimizer of SW E1. Don´t touch it and now you can use the persdonal option for the TV emissions.
Take into account tath you can also play with yor DVD settings. My DVD player have a black level and contrast adjustment.
Good luck
Saludos
Samsung S95B QD-OLED Review - A Quantum Leap for OLED!
