Black Gold
Discussion in 'Desktop & Laptop Computers Forum' started by GrahamC, Dec 12, 2003.
  1. GrahamC
    GrahamC
    Jul 22, 2001
    2,258
    Morecambe, U.K.
    +67
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,064
    +1,150
    not a lot of info.
    I wish they would spend a bit of time talking about the deinterlacing quality.
  3. mholgate
    mholgate
    Jun 9, 2003
    38
    I'm looking for a new Digital TV card to watch and record Freeview channels on my HTPC. I'd like all the functions of a PVR setup.
    Does anyone know how the MediaCenter-ready BlackGold (www.blackgold.tv) card compares to the Nebula DigiTV PCI card?
    I'm not sure yet whether I'll be using WinXP or WinXP-MCE as my OS.
    Thanks,
    Marc.
  4. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,110
    Manchester
    +713
  5. Kramer
    Kramer
    Place an order :D
    Very unlikely Kustom PCs would advertise it if it doesn't exist but.......
  6. halephil
    halephil
    May 24, 2002
    61
    I’ve been evaluating this on and off for the past few weeks.
    It’s a half height card, comes with a remote and works OK, however requires Windows Media Player 9 and frustratingly for TV recordings it re-encodes/wraps the native digital broadcast MPEG2 stream to a dvr-ms format which is only playable in WMP9. Disappointingly for Radio it re-encodes the MP2 stream to a lower bit rate.
    I’d hope these current short comings are resolved in future software releases but for now I’d continue to recommend the Nebula DigiTV
    Phil
  7. GrahamC
    GrahamC
    Jul 22, 2001
    2,258
    Morecambe, U.K.
    +67
    Well strike that of the list then.:thumbsdow
  8. mholgate
    mholgate
    Jun 9, 2003
    38
    agreed - I'll be going for the Nebula just after Christmas. :cool:
  9. Mr.D
    Mr.D
    Jul 14, 2000
    11,064
    +1,150
    The Nebula is excellent with the latest software.
    Smoothest its looked so far.
    Next year I'll be buying another to utilise the twin tuner recording option thats in the pipeline.
  10. kevshed
    kevshed
    Oct 30, 2002
    1,157
    48
    bournemouth
    +74
    I Have one of these cards - is designed to be used with Windows XP Media Centre edition, and is sold to OEMs direct as a rule (although you can buy it via their web site) - this is the reason that it uses the DVR-MS Wrapper, - but, its a very good card - would recommend it for self build media centre PCs without a doubt...
    Definatly not Vapor ware....
    Kev
