Black fuzz moving across screen on an av blue.
Discussion in 'LCD & LED LCD TVs Forum' started by Blob, Aug 30, 2005.
Tags:
  1. Blob
    Blob
    I had my Philips 17" lcd tv for about half a year now and i have always had this issue with it.
    It is plugged into a freeview box and when I go on to the digital teletext with a av blue background I get this slight, but noticible black fuzz going horizontally across the screen.
    Is this to do with my connction or what?
    thanks
  2. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
    That sounds like a SCART problem, one of many associated with this nasty little video connector. The problem stems from it being bidirectional, I think. What's happening is that the analog TV tuner signal is leaking in to your video input signals.
    You've basically got two options, one buy a more expensive cable. Or two, open up one end of the SCART cable and cut the one that's letting the TV tuner pictures in. I'm not exactly sure what cable it is, maybe a SCART expert can tell you. Off the top of my head, I think it's #19.
  3. Woods C18
    Woods C18
    Aug 30, 2005
    4
    Ipswich
    I had this problem with my sky digibox. Try these things:-
    Plug the digibox into scart socket 2 (you will loose RGB pic, but you may have less or no interfearence)
    Switch from RGB out to PAL on freeview box. (Same thing really, just a different technique)
    I think these things may solve your problem, give it a try and see what you think.
  4. Blob
    Blob
    thanks guys,
    I've rearraged my stuff so the arial wires are away from the scart and problem solved :clap:
    Thanks again. :thumbsup:
