thanks. looks like great reviews . if you play a film with Dolby Atmos do you get no sound or does the soundbar do a conversion at all ?I bought a Sonos beam for 329 and am very impressed. Plus you can add surrounds and a sub. However Sonos is addictive so be warned...
I'd also say that for your budget the Sonos would be a great choice. If you play something with Atmos it will play fine, you just won't get the Atmos layer. It would still sound very good compared to the inbuilt speakers of the gz950 (which I have). Cheersthanks. looks like great reviews . if you play a film with Dolby Atmos do you get no sound or does the soundbar do a conversion at all ?
thanks any thoughts on the Sonos vs Sony HT-X8500 ??I'd also say that for your budget the Sonos would be a great choice. If you play something with Atmos it will play fine, you just won't get the Atmos layer. It would still sound very good compared to the inbuilt speakers of the gz950 (which I have). Cheers
I've not listened to the Sony I'm afraid. Just the Sonos which I liked because for the size I thought it was very well made, sounded great and was very clever and flexible.thanks any thoughts on the Sonos vs Sony HT-X8500 ??
thanks again
