"Black framing" a Toshiba 36ZP48?
Discussion in 'Home Cinema Building DIY' started by ddlooping, Oct 15, 2004.
  1. ddlooping
    ddlooping
    Oct 7, 2003
    1,413
    Essex
    +27
    Hi all. :)
    Does anyone know where I can get some black plexiglass (or equivalent material) to make a black frame for a Toshiba 36ZP48?
    It would have to be cut to size, and would be attached to the set using blu-tack. :D
    [​IMG]
    TIA. ;)
    P.S: I forgot to mentionned I'm located in Chelmsford/Essex.
  2. ddlooping
    ddlooping
    Oct 7, 2003
    1,413
    Essex
    +27
    Nobody? :(
  3. Mat-Moo
    Mat-Moo
    Jan 7, 2003
    766
    +6
    Just normlay clear plexi and spray the back black?
  4. phils_wicked
    phils_wicked
    Mar 11, 2003
    545
    Luton (UK)
    +16
    Id paint it black with some high gloss rattle cans, or if you wanted a slightly opaque look then get hold of some light tinting spray (halfords, car modding websites etc) and use that.
    orrrrr (just thought)
    Use some car window tinting film and stick it on the plexiglass, you wouldnt need much and would have a choice of tint. Plus it would produce a nice flat finish, no drips, pitting etc.
    HTH
  5. ddlooping
    ddlooping
    Oct 7, 2003
    1,413
    Essex
    +27
    Thanks for the suggestions, guys. :smashin:
    Sorry I did not reply sooner, Mat, I did not receive an email notification.
    My initial idea was to paint the frame black using car spray, but I wanted the "customisation" to be easily reversible, just in case. ;)
    Spraying clear plexi or using tinting film could be a solution, but I still believe using black plexi would ultimately look better.
    It just seems hard to find (and having it cut to measure). :rolleyes:
  6. phils_wicked
    phils_wicked
    Mar 11, 2003
    545
    Luton (UK)
    +16
    Have you tried protech plastics? tel. 01325 310520
    or
    Advent Plastics Ltd, tel. 01933 224716
    Could be worth phoning and asking them, might even be able to cut it for you given the specs.
  7. ddlooping
    ddlooping
    Oct 7, 2003
    1,413
    Essex
    +27
    Thanks for the info, PW, I'll give them both a try. :)
  8. MikeRJ
    MikeRJ
    Oct 21, 2004
    226
    Plymouth
    I would have thought perspex would be too shiny and coul cause annoying reflections. Surely a mat finish would be better?
  9. ddlooping
    ddlooping
    Oct 7, 2003
    1,413
    Essex
    +27
