Black Bars On TV
Discussion in 'General TV Discussions Forum' started by c2k, Sep 1, 2001.
  1. c2k
    c2k
    On my 28inch toshiba, the black bars at the top and bottom come into the screen about 4 inchs each. So now my tv screen is so small, like a 21inch widescreen equiavalent. Any remdies to fix this problem?? Any ideas why it does this????
  2. raigraphixs
    raigraphixs
    Jul 11, 2001
    59,915
    +21,701
    Is it a widescreen tv? You must give a detailed question first. If yes, it is normal. Depends on what ratio the programmes are broadcasting at, the bars may come and go, or change size.
    rai
  3. c2k
    c2k
    It's a 4:3 television. It's pretty old! It the tv broken because the black bars are bigger than normal. About 3 inchs in on each bar!
  4. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,602
    7
    167
    Birmingham, UK
    +10,466
    What do you mean, bigger than normal? What do you consider normal?<br />What source material are you using?<br />As doubledoom says, do the maths.
    [ 02-09-2001: Message edited by: Spectre ]</p>
  5. Doubledoom
    Doubledoom
    As Rai says, you don't give enough information.
    Your television ratio is either 4:3 or 16:9. Broadcast material or recordings can be all sorts of aspect ratios, such as 4:3, 14:9, 16:9, 2.35:1, 1.85:1, 1.66:1 and so on.
    You do the maths and you will realise why there are black bars
  6. Kevo
    Kevo
    Aug 23, 2001
    5,398
    Manchester
    +149
    c2k
    You do realise that broadcasters are putting a lot of material out in widescreen.
    Regardless of whether you are watching analog or digital, some programmes (not all) will result in black borders on a 4:3 TV. Channel 4 do this a lot.
    Usually you should only see very small black borders
