Black bar on screen on 9527
Discussion in 'General TV Discussions Forum' started by greenthumb, Aug 13, 2002.
  1. greenthumb
    greenthumb
    Hi, Ive got a black vertical bar 2/3 to the right on my tv whenever i watch a scart source.
    I have a qed sqart fully wired cable so sheilding shouldnt be a problem.
    I only see it on dark scenes or when the screen is black.
    Watching 13 ghosts last night it became quite noticeable(dark film).
    Has this anything to do with poor internal sheilding or have I got a duff?
    It is evident on all scart sockets and the only way to rid it is turn the brightness/contrast right down to the point where i cant really see much else either.
    Has anyone else experienced this?
    Btw the bar is static.
    thanks
  2. Migueloncillo
    Migueloncillo
    Jul 22, 2002
    15
    When I watch the television by EXT 1 (DVD, RGB) or by EXT3 (digital satelite, RGB), only in the dark scenes, I see 2 vertical bars, one near the left side, an other just a few to the right of the middle line of the screen.
    It is a very little problem, because I must think in the two bars to see them y the dark scenes.
  3. Squirrel God
    Squirrel God
    It could be the infamous "black bars" problem caused by Philips using Panasonic Tau tubes. In which case, it's normal.
  4. Migueloncillo
    Migueloncillo
    Jul 22, 2002
    15
    My 32pw9527 has a Philips tube ;)
  5. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    I think this is the case with all the Phips 100Hz sets based on the MG chassis. It seems like the blanking pulses for the output leaks into the input. At least on Philips sets they are static, unlike the infamous scrolling bars on the Sony sets...
  6. Migueloncillo
    Migueloncillo
    Jul 22, 2002
    15
  7. madhouse22
    madhouse22
    I am so glad you posted this as I have had my TV for 3 weeks , I did concider sending it back as I thought it was a fault. Yes I also have the black vertical bars.
    Any luck with the picture as mine breaks up when watching Sky when there is quick movement?
  8. Gordon A
    Gordon A
    Mar 23, 2002
    145
    +37
    I've also got two black bars on the 32PW9527, but they're only visible in very light scenes. 99% of the time they're not there, but on last night's Star Wars film (with some of the snow footage) they definitely were!
    Also, I've got a line running top to bottom approximately 1" or so from the left hand side. It's there all the time and again, is more prominent on lighter scenes. It appears as a thin 'brighter than the surrounding picture' line.
    Have only had the set since August but it's hard not to notice these lines once they're known about!
  9. HowieC
    HowieC
    Jun 9, 2002
    251
    London
    Not a trace of black bar/s on my 32pw9527 I wonder if some sets have the mod already fitted.
  10. Migueloncillo
    Migueloncillo
    Jul 22, 2002
    15
    Here is the web :
    Assistance Technique TV in France
    It´s a very good page.
    You can see the chasis of every TV set and his frecuents problems.
    The chasis of my 32pw9527 is the "EM5E".
    I hope the solution for the black bars soon.
  11. -Jay-
    -Jay-
    Jul 26, 2002
    4,934
    Kop End
    +135
    sorry to bring this page back.but i`ve just got the 32pw9576 & it has 2 dark bars on the screen & would just like to know if the ring around the wires worked & got rid of the dark bars.
  12. roboldham
    roboldham
    Just briging this post to thr top.
    Anyone had this ring fitted ass suggested earlier on the French site?
    R
  13. greenthumb
    greenthumb
    I see that the chassis EM2E has the black bar problem documented and resolved on the french site.
    im sure the fault must be the same as it states that it occurs on peritel(scart) connections.
    There is a detailed solution with photos.
    Does anyone know what tv this chassis no. relates to?
    How did you find your chassis no.?
    btw i see the EM3E suffers from a similar problem only this chassis requires ferrite rings whereas the EM2E has a different fix for the same problem:confused:
  14. PaulJ
    PaulJ
    The engineer wrote my chassis no. down when he came to look at tv. I think it was just on the back of the tv.
    My chassis no. was SEM5E AA ?? I have the dark bar problem, and my tv already has the ferrite ring on.
    Im hoping to get a replacement, and see if it is any better.
  15. drummerboy
    drummerboy
    Aug 23, 2002
    90
    Leics, UK
    +5
    Anyone looked at here recently, (as originally posted by Migueloncillo).
    Its been updated.
    Looking at this section, it appears that there is a solution to a/the black bars problem posted for the MG3.x chassis (obviously of interest to owners of the 32PW9617), but not the EM5E as yet.
  16. greenthumb
    greenthumb
    Aha so the em3 is the 9617. i see the update was posted this month so maybe, just maybe we will see the 9527 fix very soon. Then we will only have to wait for the rest of the world to know about it and then finally Philips might swallow their pride and get their collective arses into gear and admit they are wrong!
