Black and White picture from Sky +
Discussion in 'Sky Digital TV Forum' started by ginga_dj, Nov 4, 2004.
  1. ginga_dj
    ginga_dj
    Jan 12, 2003
    48
    I am currently using Sky+ with a Scart into AV2 on my TV (Non RGB) as AV1 is being used by my DVD/Receiver (RGB SCART).
    However, the receiver can take inputs from a digibox using S-Video.
    When I use the S-video out from the SKY+ to the receiver, the picture is very sharp, but in black and white.
    Does anyone have any suggestions?
  2. pentode
    pentode
    Dec 17, 2002
    109
    West London, UK
    +4
    You didn't say the make/model of your TV but the most likely cause is the setting on the TV for AV2. It needs to set to s-video - if it is set to composite then you will just get a black & white picture from an s-video signal.
  3. HMHB
    HMHB
    Nov 11, 2001
    27,187
    Nottinghamshire
    +6,125
    If it's a Panasonic you may need to press the AV2 button twice as it toggles between AV2 and AV2/S
  4. ginga_dj
    ginga_dj
    Jan 12, 2003
    48
    My TV is a toshiba 32z44b. I am not sure that there is any settings I can change to make the scart accept s video.... besides, the s-video from the sky goes into the jvc av receiver, which is then output to the TV by RGB scart
