What are my alternatives?
There are plenty of alternative subwoofers in the £500-700 price range, although none that can touch the P12-300SB-PR in terms of value and performance.
However, the
REL HT/1205 is certainly a good choice, benefiting from the company's experience and subwoofer expertise. Its low-frequency delivery is superb and, thanks to a 12-inch driver and 500W of Class D amplification, it goes deep but remains controlled. As a result, bass remains tight rather than boomy, with a performance that has power and agility. However, it doesn't go as low as the BK, and at £699 it's very pricey.
The
Fyne Audio F3-12 looks better value at £599 but it's still expensive compared to the P12-300SB-PR. However, the F3-12 is a genuinely impressive subwoofer, with a ported cabinet that hits the lower frequencies, while remaining surprisingly agile and controlled. There's excellent responsiveness and plenty of detail, as this subwoofer delivers a performance that feels deeper than its quoted specs.
In terms of other choices, the
XTZ 12.17 is another cracking sub that also produces deep and controlled bass with power and responsiveness, and it will also set you back £599. Finally, there's the
SVS PB-1000, which has been around for a while but remains an excellent ported sub with deep bass and plenty of power. Best of all it only costs £519, which puts it at the turnstile of the P12-300SB-PR's ballpark.
