BK XLS200 set up problems
Discussion in 'Subwoofers' started by crackles, Oct 7, 2004.
  1. crackles
    crackles
    Hi guys,
    After the advice here of which sub to buy, (thanks all) I have just taken delivery of a BKXLS200 whick looks wonderful :) :thumbsup:
    Problem is I can't get it to work! Its operating as expected with the test signal from my VSXAX3 but I can't get it to to do anything with a DVD source.
    The fronts (tannoy R3s & RC) & rears (Mission M73i's) work perfectly in surround.
    I've been using the Starwars & the opening sequence of Goldmember (lots of bass) as a test but no sub output at all (even when amp indicates LFE output).
    I've got the sub connected via a single phono (low level) to the amp (sub) single preout. The amp is taking a digital signal from the DVD.
    HELP! What am I doing wrong? :)))))
    :lease:
    I've not tried the high level input yet, why this an option for an sub with a built in amp anyway?
    I must admit, I really am clueless!!
  2. avanzato
    avanzato
    Jan 21, 2003
    1,969
    Norfolk
    +82
    If you're getting the subwoofer test tone from the amp through the sub then it's probably your speaker setup on the amp that's at fault.
    I guess the fronts have been set as 'large' and the LFE bass is also being redirected to them as well. I don't have the Pioneer but there'll be a menu item for sending the bass to the sub, set that to sub and it should all work OK. Or just go through the amps setup routine again and hope it gets the settings right.
  3. Pollywoggle
    Pollywoggle
    Aug 14, 2000
    1,452
    South Shropshire
    +88
    Is there an option on your amp to set subwoofer to "yes"!
    As avanzato says it surely must be a setup snag with your amp?
  4. crackles
    crackles
    Avanzo, pollywoggle,
    THANKS!!!! :clap:
    You were absolutely right. Speakers were set to large, and sub was yes,....but...there is another setting to limit the signal to the sub to limit distortion. This was at zero!!! Raised to -20dB (whatever that means :) ) and now DVD's rock throght a stonking sub!
    Thanks guys,
    Crackles
    (it does hum a little at times though!)
  5. Xstyle
    Xstyle
    Sep 27, 2004
    3,497
    Berkshire
    +146
  6. Xstyle
    Xstyle
    Sep 27, 2004
    3,497
    Berkshire
    +146
    Crackles...
    So how happy are you with your BK xls200??
    Any other comments?
