nheather
I have had my BK XLS200 for many years and it is worked flawlessly until recently.
What has started happening is that the sometimes (and getting more frequent) when switched on the Sub-Woofer will rumble quite loudly and continuously with no input. I know it is the sub and not the source because pulling the LFE phono input does not stop it.
What does stop it is switching it off and back on. But even this is getting less effective. I’d say it has been happening for the last 3 or 4 months. At first just a click off and on would sort it. Over time that degraded so that I might have to switch off/on twice. And more recently, it sometimes take 4 or 5 off/on cyles.
The setup has not changed and when I do reset subwoofer it then works fine until the next occurence which could be hours or days away.
Anyone seen anything like this, or know the cause/fix. If I were to guess I’d say capacitors getting old and degraded - only because they are the electronics components most likely to degrade over time.
Cheers,
Nigel
Cheers,
Nigel
