• Welcome to AVForums running Xenforo 2.2. The upgrade from 2.1 was successful and finished in just 90 minutes, well before 8am. The most notable changes in 2.2 are listed in this post.
Question BK XLS Question - Humming?
TheRoverdog
Hi Members - Question - I have just received a lovely BK XLS400 purchased on these very forums and I have carefully set it up in position and cabled up with my Marantz NR1606 7.2 set up.. The Question... The Gain from the previous owner was set to 0 on the dial.. Once turned on I could hear a very slight hum/buzz - really low volume but you could JUST hear it if you had your head at the back of the unit.. Turn the Gain Dial one quarter and it gets louder, Turn Gain dial to half way it gets louder still and turn gain to max it's a very obvious louder Hum.
Is this normal for a BK XLS400? Do Other BK XLS400 users just get used to it?
Thanks Guys - I hope someone can help as it's a lovely looking Sub -
shotokan101
Is it there with nothing connected and how are you connecting it?
Basically shouldn't have a hum if it's ok and all your mains and earthing connections are ok
TheRoverdog
Thanks for reply buddy - So...
1. When plugged into mains ONLY (No other cables connected) - Gain on 0 - No hum - Turn slowly to Max Gain - No Hum..
2. I have tried TWO different low level connections to Receiver Sub output (1 x Male to 1 x Male connection and also purchased a 1 x Male to 2 x Sub Male cable) - Gain on 0 - Slight Hum - Turn slowly to Max Gain - Hum gets louder..
So I am going to return the second cable (unless there is any benefit for having a double connection at the sub end? Who knows? Someone on here maybe..
But any thoughts from the members here (including Shotokan101) would be appreciated. I was really looking forward to using it after buying it from a lovely bloke on the forums last week - But I just don't want the hum when using it - I was using a T2 (KEF) before which was perfectly silent... :(
shotokan101
Sounds as if the hum is coming from other equipment - pun intended :)
How are you connecting the sunpb and your amp to the mains - powerstrip or individual mains sockets?
TheRoverdog
Yeah I thought about the mains maybe being an issue - I just tried it plugged into the same extension strip as the receiver.. still a hum when RCA connected, tried it in it's own mains plug on other side of room... still a hum (but I think less - or that's in my head) - Tried turning off (one at a time - Freezer, Fridge, Microwave... Couldn't think what else to turn off?!)
shotokan101
With sub cable (not just a spare phono/RCA?) Connected Oly to the sub and not amp is there a hum and how long is the sub cable?
TheRoverdog
OK ta... With Just Sub Cable plugged into Sub (Not connected to Receiver, just sat on floor) Hum gone.. With Gain at MAX you can hear a tiny teeny hum but pretty sure that's just the power of the amp on the sub (you can't hear it more than ear 10cm away :) IF I go to unplug the cable whilst powered on my hand touching the RCA socket on the sub causes hum but that's probably my fingers causing that...
shotokan101
So maybe something plugged into the receiver? :(
Possibly - can you just confirm that the connecting cable is a proper shielded sub coax and not a spare RCA phono cable?
Is the hum present with the amp connected but in standby and what about if powered off but plugged into mains?
Obviously worth disconnecting all devices from amp and rechecking and if no hum then connect one at a time to narrow it down
Jim
MI55ION
This little device can work wonders to remove hum from a system.
Amazon product
You'll also need a pair of rca to 1/4" TRS cables.
Amazon product
TheRoverdog
Morning peeps.. ok.. did a process of illumination test this morning.. sub in gain max so easy to hear hum..
1. Sub on.. no rca connected.. no hum
2. Sub on.. rca connected without any remote connection.. no hum
3. Sub on.. rca connected to receiver but receiver off at mains.. no hum
4. Sub on.. rca connected to receiver, mains on but in standby.. HUM
5. Sub on.. rca connected to receiver, receiver plugged directly into mains (not extension).. HUM
6. Sub on.. rca connected to receiver, all other devices disconnected.. HUM
So.. I guess.. the Sub is getting hum from receiver solo when it has any power to it, even in standby..
TheRoverdog
Oh well that didn't work lol.. having spent out on cables, loop isolaters etc. I've now paid more than I could have got a refurb direct from BK for ha ha! :^(
Maybe these BK XXLS400-DF subs just hum.. who knows.. I've dropped the Gain back to halfway so the hum is way quieter. Maybe back to the KEF T2.. I read about BK Hum or REL Hum and I guess people just accept it as part of having one but having come from a silent T2 it's just annoying :^(
EdwardScissors
hey guys im the seller. I had it plugged straight into a wall. Im not an expert but it sounds like something else is causing it. Im not trying to shift the blame im trying to help. I just dont know why your other sub was fine but this one isnt.
password1
Maybe it's the receiver. do you have a different reciever or amp you can try? Does it hum from a maibs in a different room?
TheRoverdog
I've found a workaround! :^) I've increased the sub level on the Marantz NR1606 and turned the Gain down on the BK so all good. Too be fair I shouldn't have the gain past half way anyway.. All good chaps.. this gives me the bass without Gain being high so all good..
TheRoverdog
I'm getting a new receiver in two weeks anyways. Looking for an Earc one... it could well be the NR1606.. To be fair if I have the Sub ON with no RCA connected with max gain.. no hum.. RCA connected to marantz (powered off) no hum.. it's as soon as power goes on on receiver.. hum from gain halfway to gain max (never going to have it passed halfway anyway) .. the sub is mint, I'm happy with it, I just wanted to know if the Hum was normal thats all really.. buying new cables and bits etc made me realise gain max would have a hum anyway on any receiver....
Podcast: Q Acoustics Q3030i, Humax Aura, Roku Streambar & WandaVision Reviews and more...
Latest News
KEF announces KC62 subwoofer with new Uni-Core technology
  • By Andy Bassett
  • Published
AVForums Podcast: 20th January 2021
  • By Phil Hinton
  • Published
Netflix passes 200 million subscribers to end 2020
  • By Andy Bassett
  • Published
Cyrus Audio announces soundBuds2 in-ear headphones
  • By Andy Bassett
  • Published
Audio Research launches Reference 80S power amplifier
  • By Andy Bassett
  • Published
