bk xls 400 with mk 950s and onkyo 818 ?
Discussion in 'Subwoofers' started by dinoprada2003, Mar 10, 2013.
  1. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    4,035
    2
    LONDON
    +6,827
    Just wondering in a 12x10ft room with the sub firing down from the right hand corner on a auralex platform parkee flooring on top of a concrete floor if the bk xls ff is a good choice with my setup? max budget is around the £500 mark new or s/h.
    looking for something to go well with the mk 950s and the onkyo 818 till I can get a mk 350 :D
    this really will have to be BIG step up from the velo cht10-r I have otherwise I will keep the cash and wait till I get a mk 350 lol
    movie 90% music 10%
  2. Member 639844
    Member 639844
    Former Advertiser
    Sep 2, 2007
    14,799
    Lancashire
    +1,182
    You would probably be better of getting the monolith.
  3. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    4,035
    2
    LONDON
    +6,827
    thanks moonfly I have been advised that the xls 400 would be better with mk as it is a sealed sub like actual mk subs? :)
  4. Member 639844
    Member 639844
    Former Advertiser
    Sep 2, 2007
    14,799
    Lancashire
    +1,182
    Generally speaking I would say that correct. However, most of you listening is on movies, and the Monolith is the better sub for that job. The question of integration between subs and speakers is a different matter, and generally speaking a sealed sub would be better. That said, the monolith isnt part of the breed of ported subs that aim to dig as deep as possible, and instead it tries to balance its output between depth and retaining some of that more punchy sound you generally get from sealed subs the best.
    The sealed 400 is probably the better of the two if you ultimate goal is perfect integration etc, but you have stated you want a big step up in performance as well. This being the case, and taking all else into account, I personally would say that your probably best of getting the monolith to achieve most of what you want. Thats my personal opinion anyway.
  5. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    4,035
    2
    LONDON
    +6,827
    Thank you for taking the time to reply moonfly and for the advice :) i didn't know there would be a big difference between the mono and the 400 I know or think the mono goes down about 3.5db lower ? but the 400 is supposed to be tighter? i'm just wondering what the real world pros and cons of each sub with my amp and speakers is going to be? btw if im going the mono route would there be much advantage to getting the mono plus rather than the normal mono?
  6. hifibloke
    hifibloke
    Dec 16, 2003
    302
    28
    +39
    from what I know mono+ is bit louder ,but mono apparently will dig slightly deeper
  7. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    4,035
    2
    LONDON
    +6,827
    how does the m&k 1250 thx compare to the mono and bk xxl 400?
  8. kbfern
    kbfern
    Aug 17, 2002
    17,925
    Wolverhampton
    +6,092
    If you looked at the 1250 that was sold a couple of days ago on the classifieds the seller said he had tried an XXLS400 in the same room as the 1250 and the XXLS400 did not come close.
    At £200 the 1250 was a bargain, I was looking at it myself but need something even better really.
  9. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    4,035
    2
    LONDON
    +6,827
    ideally id like a mk 350 or even 250 but they dont seem to come up often on the forums.
    what sub are u looking for kbfern?
  10. kbfern
    kbfern
    Aug 17, 2002
    17,925
    Wolverhampton
    +6,092
    If it was used an MX350 but to be honest they are usually £700+ which is too much considering the options available for £1100-1400 that would be better and new with warranty.
    So in all probability a Gecko single 15" will be where I spend my money, although I would like to hear a KK 808 which I doubt will be as good as the 15" but is £1100 approx.
  11. Darkmatter21
    Darkmatter21
    Nov 24, 2010
    1,394
    48
    Rugby
    +80
    Its a shame as there seems to be a big gap in the market between the monolith/monolith+ at £500ish to much more expensive options at £1.3k+. I can't seem to find many talked about subs in the £800ish region!
  12. scottthehat
    scottthehat
    Jan 6, 2012
    11,160
    2
    167
    honiton
    +2,801
    The only other way Sr diy get amazing performance for alot less.
  13. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    4,035
    2
    LONDON
    +6,827
    kb do you rate geckos single 15" above a mx 350 then?
  14. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    4,035
    2
    LONDON
    +6,827
    yeah but you are talking to the man who put his his a/v cabinet shelves on back to front let alone a sub :D thats me I mean NOT sr :D
  15. kbfern
    kbfern
    Aug 17, 2002
    17,925
    Wolverhampton
    +6,092
    Well DaviF is saying the KK 12012 is way better than the MX350 and I am expecting similar performance to the 12012 from the single 15" so the answer would be the 15 should be a substantial improvement on an MX350.
    I have not heard the 15 yet though so it is conjecture at the moment + comments from folks who have heard the 15 already, I am going to gecko 24th Mar so should know for sure by then (MX350 v gecko 15).
  16. dinoprada2003
    dinoprada2003
    Jul 7, 2004
    4,035
    2
    LONDON
    +6,827
    let us know how you get on in march be interested to hear your feed back :)
    do you have a link to the gecko 15 price etc? I looked on robs site but found nowt about it.
  17. kbfern
    kbfern
    Aug 17, 2002
    17,925
    Wolverhampton
    +6,092
    A single 15" with a 3000 watt amp in basic black vinyl finish should be £1395.
