BK Monolith Crossover question...
Discussion in 'Subwoofers' started by CallMeSteve, Feb 3, 2009.
  1. CallMeSteve
    CallMeSteve
    Feb 13, 2008
    3,625
    83
    +152
    Can someone tell me if the crossover on the Monolith should be set to max once the dial clicks or just before the dial clicks?
    Thanks :thumbsup:
  2. namuk
    namuk
    Oct 23, 2006
    22,187
    +4,332
    Dial clicks = 120hz :thumbsup:
  3. CallMeSteve
    CallMeSteve
    Feb 13, 2008
    3,625
    83
    +152
    Thanks, just to check... When listening to music in stereo with the sub, I get dialogue through the sub when its clicked into 120HZ, is that right?
  4. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    Spaghetti Junction (really)
    +1,923
    Yes it's right. But it's wrong :)
    Because the Primare has no way of controlling the crossover, you'll have to use the Monolith's setting.
  5. CallMeSteve
    CallMeSteve
    Feb 13, 2008
    3,625
    83
    +152
    You had me going there for a minute :D. Pheeew!
  6. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    +1,923
    It sounds like the Arcams x-over setting is too high, I'd lower it.
  7. CallMeSteve
    CallMeSteve
    Feb 13, 2008
    3,625
    83
    +152
    The Arcam is set to 60Hz. I'm going to play around with it and the SMS1 to try and figure it out. :thumbsup:
  8. Badger0-0
    Badger0-0
    May 30, 2005
    20,601
    +1,923
    Strange :confused:
    Whatever, you might be able to use the Monolith's x-over too :)
