BK Gemini Mk2 or Velodyne CHT-10Q
Discussion in 'Subwoofers' started by Flying Ryan, Sep 7, 2012.
  1. Flying Ryan
    Flying Ryan
    May 12, 2011
    11
    3
    Hi everyone
    Bearing in mind both of these (BK Gemini Mk2 or Velodyne CHT-10Q) can both be found for around £250 at the moment, which of these would be the best to buy?
    And would they partner well with my B&W cm1 fronts, cm centre.
    Used for 60% movies and 40% music
    Thanks in advance for any feedback.
  2. Spock
    Spock
    Jan 3, 2007
    203
    +20
    I would take the cht10 or maybe save the extra and go for the 12" version. Don't count out the bk xls200 either!
  3. Flying Ryan
    Flying Ryan
    May 12, 2011
    11
    3
    Thank you for your reply, I thought that velodyne seemed like a good deal and will try and get to listen to it. It's a shame I cannot directly compare it to the bk offerings
