BK 400 hi level advice (help)
  • Thread starter Deleted member 598831
  • Start date
D
Good evening folks. After looking at the b-tech 934 to control high level out to run 2 bk xxls 400's, it appears it will not work.
Because I use the subs in two systems I am looking for a manual adjustment unit. If i run the sub out of a yamaha as-500, with a splitter lead, then put it into the line in on this tripath amp Class T Amp 25Wx2 Amplifier Tripath TA2021 SMSL B+PSU | eBay
then I can use this to reduce the subs when needed?
My only issue is about the btl output bit? Will it be ok to wire using the bk lead, pos left, pos right and either neg, or do I need to use two negatives?:rolleyes:
Steve
