Bizarre problem with JVC LT-32D50 and Dual dvd player
Discussion in 'LCD & LED LCD TVs' started by spencerp, Jan 14, 2005.
  1. spencerp
    spencerp
    Dec 30, 2004
    20
    Some of you may have read my other thread concerning problems I was encountering with my new tv. In a nutshell it would only display a good dvd picture through the Ext 2 Scart socket, using Ext 1 resulted in a washed out green picture. In despair I tried a friends dvd player last night and lo and behold it works fine in both sockets (in both rgb and pal modes) so it seems that for some nutty reason the Dual doesn't like the Ext 1 scart socket on my tv. The only difference between the two is the Scart 2 is designed to export a signal (either from the tv or patched through one of the other inputs) to a vcr or other device, Scart 1 can only output an analogue tv picture (I think, if I understand the manual correctly). Lord knows why my Dual takes exception to this but I'm just pleased I've finally got to the bottom of it. :)
  2. GaryB
    GaryB
    Nov 12, 2002
    5,346
    St Albans
    +1,267
  3. spencerp
    spencerp
    Dec 30, 2004
    20
    Took the Dual dvd player back to Asda and got a refund. Went straight out and bought a Toshiba dvd/vcr combo and now all is well.
