biwiring
Discussion in 'Home Cinema Speakers' started by rdt123, Jan 12, 2003.
  1. rdt123
    rdt123
    Dec 14, 2002
    1,516
    Busting out a restaraunt in Queens, NY
    +33
    Hello
    My wharfedale diamond 8 speakers are biwirable. My yamaha v630rds has terminals for two sets of mains A + B.
    Is it possible to biwire these speakers from these terminals and if so is there any point?
    cheers
  2. bob007
    bob007
    You can Bi-wire using these terminals.
    TBO there's little point, you would be better of replacing the jumper bars with some good quality speaker cable.
  3. paiger
    paiger
    Isn't this bi-amping? I though bi-wiring was connecting each output on the amp to seperate cones using 2 cables. So you would connect the red L main with two cables, one to each red connector on the speaker.
    Innit?
    S
  4. bob007
    bob007
    The Yamaha has A+B for the mains, so you can connect the LF to "A" and the HF to "B", select A and B on the front of the amp and you have Bi-wired the said speakers. ;)
