biwiring/biamping
Discussion in 'Home Cinema Speakers' started by BrianC, Sep 29, 2003.
  1. BrianC
    BrianC
    Jan 20, 2003
    2,190
    +101
    appologies if I've made any mistakes with this:
    with my amp its possible to wire up the a & b speakers to a single pair of speakers, running at 6 ohms. What do I need to do
    in order for this to work, special speakers?
    ta!
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,295
    United Kingdom
    +1,572
    Your speakers need to have 2 sets of binding posts to achieve bi-wiring. Using the A+B speaker outputs from most amps/receivers isn't bi-amping as they usually share the internal amplification. You would need another seperate amplifier.
  3. andymc
    andymc
    Sep 18, 2003
    266
    Bedford
    +15
    you need speakers that can be bi-wired - this is basically where there are two sets of binging posts on the rear - One set for the bass frequecies and one for the upper/mid frequencies.
    I would not recommend you wire from the a & b sets of speakers - I would wire from one set on the back of the amp to the pair on the speakers. Use a dedicated biwire cable for this. Something like QED Silver Anniversary is very good at around £8 per metre...
    Does this makes sense and what equipment are you running this with???
    Andy Cuthbert
  4. BrianC
    BrianC
    Jan 20, 2003
    2,190
    +101
    its a yammy 630 RDS. I have only one set of posts for left & right for a, and again for b speakers.
  5. nathan_silly
    nathan_silly
    To be honest I wouldn't bother. To get real benefits of biamping you need to go down a bit more higher end gear- say Arcam A75 and P75 area. And not a budget AV Amp.
    If you want to upgrade, consider replacing the poweramp stage in the Yamaha with a high power multi-channel poweramp- say Rotel 1075 or 1095 latter 200W per channel!! :)
  6. BrianC
    BrianC
    Jan 20, 2003
    2,190
    +101
    thanks for the advice, I wasn't sure if:
    1) It was possible
    2) If it was worth doing
    I'm just about to buy some new speakers (one set of each of the Tannoy R) so I wanted to check if I should be looking to biwire or not.
    Amps due to be replaced in about 6 months (I work on a 24 month replacment cycle :rolleyes: ) so I'll upgrade that then.
  7. nathan_silly
    nathan_silly
    1) - not with that Yamaha. If you REALLY wanted to bi-amp with that amp, you'll need a 2 channel poweramp with the same gain and characteristics as the Yamaha (input gain and overall sound)
    For example, I tried using a Arcam Alpha 9 integrated with a Arcam Alpha 8 Poweramp- you think it'll work OK. However the amp gains are different- at any volume they are not equal (due to different gains)- using a Alpha 9P solved this (same gain)
    Since Yamaha don't produce a 2 channel poweramp you're pretty much stuffed (unless you find a poweramp that's identical)
    A easier option is to buy a 4 channel poweramp (or two x 2 channel poweramps) and send the Left & Right Pre-outs into these poweramps. The Yamaha's Left/Right pre-outs will be unused.
    2)- as before, need to go into a slightly better IMO, to get the sound quality noticeable sound quality improvement.
    I have biamped my Hi-Fi speakers for my music system (big improvement)- and also front three speakers in my AV system (not so much of a improvement, more better control- although I've only just biamped the AV Left/Right speakers)
