Bitrates in Studio 8
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by mab25, Jan 14, 2004.
  1. mab25
    mab25
    What is the best bitrate to use when creating a DVD in Pinnacle studio 8. The maximum bitrate seems to be 8000kbps but is the quality noticably better than using a 6000kbps bitrate for example.
    I think SVCD's are created with a 2500kbps bitrate (well below 8000) but the quality is not that far away from DVD.
    I want to establish the best bitrate to use, where any increase in this bitrate would give only negligable quality improvements but would increase rendering time and space taken on a DVD.
    The camera I am using is a Sony Digital 8 (if that makes any difference)
    Advice would be appreciated.
    Thanks,
    M.
  2. mossmanfly
    mossmanfly
    Jan 6, 2004
    568
    28
    Worcestershire
    +46
    With Bitrates it all depends on the footage. DVDs have variable bitrates the same as SVCDs. So in fast moving action sequences to give a good picture the bitrate will change to a higher bitrate, and once the action stops the bitrate will lower. If you have a DVD player on the PC and PowerDVD. If you select "show information" you get the bitrate, will probably be in other software as well but only use PowerDVD so only know its on there.
    The best way to encode footage would be to use a variable bit rate at say 2 pass. This would mean that the program will analyse the video and then encode it to the best rate it can with the bitrates you set.
    Try out a few different settings, by converting a 2 minute section. See which encoding method is the best. Variable bit rate takes alot longer than a constant bitrate, but should give a better result in the end.
  3. Brian110507
    Brian110507
