Bitrate problem on TMPGEnc
Discussion in 'Blu-ray & DVD Players & Recorders' started by witters, Nov 11, 2004.
  1. witters
    witters
    Jul 13, 2000
    12,185
    Yorkshire
    +287
    I have just used TMPGEnc 1.6 to capture some vido from a DVD-RW in VR mode. All went OK until I tried to output it. I was then informed that the bitrate was too high? What have I done wrong? The video was captured from Sky+ in HQ mode on a Sony 300.
    TIA
  2. witters
    witters
    Jul 13, 2000
    12,185
    Yorkshire
    +287
    Anyone please?
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    The most likely cause would probably be due to your audio settings - are you using DD or LPCM? The Video bitrate certainly couldn't push the overall datarate above the maximum allowed on it's own.
    I suggest trying to do some tests: does it reject all HQ recordings? How about SP?
  4. witters
    witters
    Jul 13, 2000
    12,185
    Yorkshire
    +287
    DD - and it rejects all Rec mode settings?
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    That doesn't sound good - does the GX300 have a hybrid/advanced resolution setting? If so set it to 'Fixed'/'Locked'.
  6. witters
    witters
    Jul 13, 2000
    12,185
    Yorkshire
    +287
    Does not seem to have.?
