Bit the bullet and bought a
Discussion in 'LCD & LED LCD TVs Forum' started by ibmike, Apr 2, 2005.
Tags:
  1. ibmike
    ibmike
    New lcd tv
    After searching all my local shops and supermarkets unable to find a sonix had the video 7 version but was dead on arrival which made me lose faith and then it took 2 weeks to be collected
    I went to my local comet store and bought one of these beauties
    Specs Here
    [​IMG]
  2. crazyswede
    crazyswede
    Feb 13, 2005
    77
    9
    Chester
    So what do you think?
    How's normal TV? DVD?
    Are you happy? :)
  3. emu
    emu
    Nov 10, 2004
    3,017
    71
    new milton
    +73
    ibmike
    i did exactly the same thing as you :thumbsup:
    went down to buy the sonix but couldnt find stock anywhere :thumbsdow
    using the lg in the bedroom with sky +,xbox,ps2 and gamecube all giving great results :)
    just need to find a dvi dvd player now :D
  4. badboy killa
    badboy killa
    according to comet it doesnt have DVI?
  5. ibmike
    ibmike
    It does have dvi and luckily it comes with dvi cable and vga-dvi cable
    I find it great with both my pc and ps2 and normal tv is very ood i have not even had to change any settings just plug in auto set up and is amazing to be honest i am glad i shelled out the extra
    I have had a few lg items and all have served excellent
  6. emu
    emu
    Nov 10, 2004
    3,017
    71
    new milton
    +73
    im normally a bit of a brand stickler ie sony,panasonic and denon
    but this lg tv has been perfect for the bedroom its got a better pic than the 28 inch crt toshiba it replaced :)
  7. Faust
    Faust
    Dec 21, 2002
    3,217
    UK
    +663
    What about RGB scart? Comet specs says no, have they got this wrong, if not that seems on the face of it to be a glaring omission, especially if you have Sky.
  8. emu
    emu
    Nov 10, 2004
    3,017
    71
    new milton
    +73
    lol @ comet specs
    i wouldnt believe a word of specs they put on tvs as far as i can tell scart is rgb
  9. ibmike
    ibmike
    Right then it has
    2 X Scarts
    1 X DVI
    1 X RGB
    1 X SVID
    Also PC Audio in
    And Audio in for Either Svid or rgb
    I must admit i do like LG products
    From my experience they are in the same quality leauge as the likes of sony etc but have a much more competative price range
    Link To LG site the link provided goes straight to the tv and specs
  10. emu
    emu
    Nov 10, 2004
    3,017
    71
    new milton
    +73
    looking at a way to feed sound from tv into my sony davs550 now
    speakers are ok but i would like a bit more oomph on the sound
    i presume a lead from scart 2 would send audio out?
  11. fatty 99
    fatty 99
    Nov 23, 2003
    137
    could you please tell me if its got a component socket on it because comet says it has but lg website says it hasnt.
  12. ibmike
    ibmike
    By this you mean the red green and blue inputs ???
    If so then yes it has
  13. fatty 99
    fatty 99
    Nov 23, 2003
    137
    thanks for the help
  14. fatty 99
    fatty 99
    Nov 23, 2003
    137
    could you tell me what the response time is because im thinking of getting one for watching dvds and playing xbox
  15. fatty 99
    fatty 99
    Nov 23, 2003
    137
    anyone help ,thinking of buying tomorrow
  16. handsome devil
    handsome devil
    hi this is first post was thinking of getting plasma till isaw the lg rz37lz30 i was hoping to connect it to dennon 550 with component but specs are alittle vague could anybody update me on the specs and has anboby got any views on this tv
  17. ibmike
    ibmike
    Right as for response time i have no idea
    But i have played my ps2
    Watched my freeview digi box
    Played pc games (Americas Army) and have no experienced any problems what so ever
    As for your questions handsome devil what do you want to know ????
  18. fatty 99
    fatty 99
    Nov 23, 2003
    137
    ibmike one last question,what progressive scan support can it do
    (like 480,720,1080,) thanks
  19. ibmike
    ibmike
    To be honest i have not got a clue ???
    If you tell me how to look find it i can then tell you
    Sorry but this is the first time i have ever bought a decent tv especally an lcd so i am just getting used to it all
