Bit of speaker advice please!
Discussion in 'Home Cinema Speakers' started by the_dead_parrot, Jan 9, 2004.
  1. the_dead_parrot
    the_dead_parrot
    Apr 16, 2003
    113
    16
    Rugby, Warwickshire
    Hi im fairly new to this home cinema malarky but got a aego p5 system, iv been trawling round the forum looking for tips on how to set the speakers out, and i think iv got the angles and heights about right? e.g. 30 degrees either side for front (couldnt manage that on mine i hope 25 is enough???) and 110 degrees both sides behind you... can you just give me some advice on whether there iv interpretted this info right, or is there any better way to do it?
    one thing i cant find much info on is sub placement, wheres the prefered position? or is it just a case of trial and error
    [​IMG]
    the problem im having though atm is the rear speakers should be wall mounted but the terrible speaker brackets supplied with the system only move in 40 degree increments and none of them point to the seating position (do i want them angling downwards towards my ears or should they be upright?) does anyone know of any small wall mounted speaker brackets that can hold the satellite speakers as nothing is turning up...
    thanks for any help
  2. munkay
    munkay
    Dec 19, 2003
    354
    +17
    I think the sub should be outside the fronts - perhaps beside the wall in the bottom right
  3. the_dead_parrot
    the_dead_parrot
    Apr 16, 2003
    113
    16
    Rugby, Warwickshire
    cheers do i want it so that its not facing me then? i.e. that gap inbetween the wall and bed so its firing accross the room? or should it be placed in the gap between wall and FR speaker
    any suggestions?
  4. munkay
    munkay
    Dec 19, 2003
    354
    +17
    Just try messing about with different positions to see what sounds best.
    If its front firing then try setting it facing out same dir as fronts with phase set to 0 and a bit away from the wall then go from there. May sound a bit boomy if facing wall.
  5. mightyal
    mightyal
    i read that if you place the sub in your listening position and wander about the room then the bassier the sub sounds the better that spot is to place it. Does that sentence make sense?
