Bit of quick advice needed
Discussion in 'LCD & LED LCD TVs Forum' started by robfosters, Sep 16, 2007.
Tags:
  1. robfosters
    robfosters
    Feb 8, 2007
    2,146
    +217
    We have decided to change our frontroom somewhat. With the movement our viewing position will go from 8ft to 11.5ft.
    We will change the telly as we only have a 37inch. Looking at these calculators, it says that at that distance, 50inch would be okay. Anyone think that is too much, or would you have it? My priority is HD SKY (footie, films), PS3 (gaming & blu-ray).
  2. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    Maybe the 50" is a little big,but I think that a 46" will fit well!!What is your budget?
  3. robfosters
    robfosters
    Feb 8, 2007
    2,146
    +217
    Around 2-2500K.
    I was kinda thinking about the 46 X3000, but that may be overbudget.
  4. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    The 46X3500 surely fits your budget!!!The complett which usually takes first stock and overprices sells the 46X3500 for 2199£!!!So you dont have to worry it fits!!
  5. dognosh
    dognosh
    Nov 24, 2006
    931
    28
    Somerset
    +65
    Ideal distances :
    720p and 50" = 10-12 feet
    1080p and 50" = 8 feet
  6. robfosters
    robfosters
    Feb 8, 2007
    2,146
    +217
    Now i'm confused :suicide:
  7. dognosh
    dognosh
    Nov 24, 2006
    931
    28
    Somerset
    +65
    ok, I don't know if you know about HD TV or not ? do you know 720p? 1080p?
    if yes then to appreciate the fantastic picture you get from these devices you have to place them at the ideal distance
    normally,as you have done, you measure the distance from your seated position to the TV, then you say what you will mostly watch(which you have) and from those you get the ideal TV size
    50" TV at 11 feet is ideal for 720p viewing(SKY HD is 720p and 1080i) and pretty ok for 1080p(PS3 movies+games)
    get yourself a 50 inch 720p LCD TV and save the extra you would have paid for a 1080p set :cool:
  8. dognosh
    dognosh
    Nov 24, 2006
    931
    28
    Somerset
    +65
  9. honkydonky
    honkydonky
    Feb 5, 2006
    607
    +32
    50" at 8 feet would be like the front row at the cinema, I have a 32" at 7 feet and wouldn't want any bigger you'd have to turn your head to see both sides of the screen :)
  10. dognosh
    dognosh
    Nov 24, 2006
    931
    28
    Somerset
    +65
    I only said so as I have experience in it:)
    my 42" is about 6.5 feet from me and it is ideal for my 1080p viewings:cool:
    so 50" at 8 feet sounds right:smashin:
