bit of advice with my setup and connecting other gear.
ricflairandy
Need a bit of advice please.
What do you guys think would be the best way to connect the following gear to a samsung ps42e7hd?
It has 2 scart, 1 component and 1 hdmi. And i have a yamaha rxv359 av amp to use for switching and 5.1.
Xbox
Xbox 360(soon)
Ps2
Liteon lvw5004 dvd recorder
Sky Pace digibox(not plus)
Dreambox 7000s
Basicly i want to get the best possible quality with all of these connected. But as im putting cables into the walls, i want to try and make sure that i am kind of futureproof(or as futureproof as you can be these days) as i dont fancy reopning the walls anytime soon.
All advice appreciated, thanks.
ricflairandy
At the moment, im thinking
Xbox via component - amp
ps2 via component - amp
dreambox via compoennt - amp
dvd recorder via rgb scart - tv
sky via rgb - dvd recorder
360 via hdmi - tv
amp via component - tv
Therefore needing a hdmi, a hdmi and a component cable fitting into the walls when i do the chasing this week.
Anyone got any better suggestions or spot anything ive missed?
should i also consider fitting an extra scart, composite and arial cables into the wall aswell just incase?
