Just moved into rented accommodation and want to avoid drilling holes.
1. I don't have a drill
2. It would need to be repaired
3. I don't know what type of walls these are
I have seen some 3M command sticky nails but the speakers I have are 3kg. 2 mounting points on the back. Each 3M nail is rated at 2kg.
This does seem a tad risky, otherwise I may have to change speakers for something I can place on a stand.
Options?
Options?
