Bipolar rear advice
Discussion in 'Home Cinema Speakers' started by MikeRJ, Nov 7, 2004.
  1. MikeRJ
    MikeRJ
    Oct 21, 2004
    229
    Plymouth
    Are bipolar speakers meant to be mounted behind like normal rears, or should they be mounted either side? Heard some conflicting advice on this.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    I have always mounted mine at the side
  3. Roohster
    Roohster
    Jul 1, 2004
    3,944
    3
    Derbyshire
    +4,074
    I had this very problem a couple of months ago when I changed over to bipolars...and got conflicting replies!
    I eventually put mine on the rear wall, about 5' up and 1' from the side walls.
    They sound great in this position, so to be honest, I didnt experiment much beyond this.
  4. Mr THX
    Mr THX
    Nov 26, 2002
    1,309
    Barnsley
    +32
    I'd agree with Ian J - its on the sides - got mine in line with where I sit to watch movies, this gives a nice throw of effects around you.
  5. MikeRJ
    MikeRJ
    Oct 21, 2004
    229
    Plymouth
    Hmm, 2:1 in favour of the sides. I currently have them mounted behind me, but I'm in the middle of completely changing my room layout to suit a PJ, so I'll give them a whirl mounted on the sides. Thanks chaps.
  6. EN
    EN
    Jul 24, 2000
    267
    19
    Sofia, Bulgaria
    Mines are on the sides and I got two surround backs mounted on the rear wall.
  7. ahin4114
    ahin4114
    Nov 1, 2004
    1,066
    Reading
    +48
    I run di-poles on the side, and bi-polar on the rear centre channel. This was under advice from Monitor Audio, I've always been very pleased with the effect.
    Tony
  8. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    I have my Dipolars on the sides but next to listening level, and two smaller sats behind me for the two surround back channels, sounds fantastic, and I believe is the recommended configuration for a 7.1 setup.
  9. MikeRJ
    MikeRJ
    Oct 21, 2004
    229
    Plymouth
    Since the essential difference between a bipolar and dipolar is simply the phase of the two speakers, has anyone tried converting a bipolar speaker to dipolar operation?
  10. MrJubbly
    MrJubbly
    Nov 30, 2001
    87
    Cheshire
    Could someone explain the difference between bi-pole and di-pole, and which is better suited in a 5.1 arrangement?
    Thanks.
    Jubbly
  11. Mr THX
    Mr THX
    Nov 26, 2002
    1,309
    Barnsley
    +32
    Di-pole: One of each drive unit is mounted in the opposing faces of the dipole and they are phase inverted in true dipolar configuration to produce a full surround sound effect, while at the same time maintaining left and right channel separation
    Bi-pole: Design radiates sound in 2 directions for spacious surround-sound effects. 'Bi-poles' are actually omni-directional monopoles,
    different from conventional box loudspeakers only in duplicating the forward facing drivers with more of the same firing out of the back.
    Personally I have my Monitor Audio surrounds set to Bi-pole and find the effect more pleasing......situated either side of the seating position in a 5.1 system ....... each to there own really.
  12. MrJubbly
    MrJubbly
    Nov 30, 2001
    87
    Cheshire
    Thanks for the concise reply MrTHX.
    Kind Regards,
    Jubbly
  13. steve 111
    steve 111
    Jan 5, 2003
    558
    Newport, Gwent
    Have my Monitor Audio BFXs set to bi-polar and to the side of my listening position in my 5.1 set up. Feel this gives a more 'enveloping' surround effect. Now just waiting for enough pennies to buy my second set of BFXs for the centre rears. :)
