Bios password
Discussion in 'Computer Software & Operating Systems' started by cantona.no7, Aug 4, 2006.
  1. cantona.no7
    cantona.no7
    Nov 20, 2005
    1,717
    48
    wiltshire
    +37
    as the title really got a laptop dont know the bios password my father in law cant remember it is there anything i can use to reset it?
  2. T0rNaDo
    T0rNaDo
    Sep 25, 2005
    8,394
    Essex
    +1,051
    reset the bios on the motherboard.
    normal by a jumper....
    example.......
    3 pins....... pin 1 and 2 rests bios....... pins 2 and 3 normal running mode...
    get make / model of the motherboard and search it online.
    for a manual
    unless it shows on the mobo.... that a set of 3 pins is bios reset..
  3. Member 55145
    Member 55145
    Jan 18, 2005
    12,082
    +3,483
    take the battery off the mb, or if your lucky the company that make the laptop will give you a backdoor PW(but they may only do it if your a service centre)
  4. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    Most laptop CMOS battery's are just under the keyboard, usually you just have to undo a couple of screws on the underside of the latop to remove the keyboard. These screw are usually marked differently or have a symbol on the casing next to them so you can identify them.
    Just beware that when you lift the keyboard it will usually have a quite delicate ribbon cable with a small block connector that you'll need to pop off the motherboard tp completely remove the keyboard.
    Easier than it sounds, honest :smashin:
