Bin or upgrade ???
Discussion in 'AV Receivers & Amplifiers' started by pgarbe1, Aug 11, 2003.
  1. pgarbe1
    pgarbe1
    I currently have a Bang & Olufsen (B&O) system comprising :
    Amp - B&O Beomaster 2200 (inc. 5 channel radio)
    CD - 5142 (finger touch control)
    Turntable - Beogram 1500
    Speakers - Celestion: Ditton 15xR
    I'm considering upgrading and looking for help and advice on whether its worth it or whether I'd be best starting from scratch ???
    If I were to start from scratch then is there a second hand market for my existing system ?
    I wouldn't be fussed about replacing the turntable so any new system need only comprise CD/Amp/Radio (pref. DAB) - unit or separates. I v. much like the output and compact nature of BOSE lifestyle systems - so would like any advice benchmarked against this ?
    Price bracket upto £2k
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    Many people round here are not big fans of BOSE, but are afraid to be honest and direct. Not me! BOSE is over-priced, badly put together and sounds worse than average! Avoid.
    If you want the best CD/Amp/Radio around buy a Linn Klassic (unfortunately not DAB). It is £1000 and sounds lovely - note many online dealers are giving away some nice speakers free with the Klassic right now. You can add a good DAB seperate for £120 anyway.
    Sorry, I don't know much about B & O (but I do know it is pricey too) but I have heard of some cabling idiosyncracies making some of them difficult to mix with other makers. Second-hand it may be worth something. Call a B & O dealer or check E-Bay for examples.
  3. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,190
    Weardale
    +57
    does B&O = bose..? hmm...eitherway, both aren't real hi-fi...best bin and start afresh...
  4. NicolasB
    NicolasB
    Oct 3, 2002
    5,876
    Emily's Shop
    +566
    B&O = Bang And Olufsen :confused:
  5. menalaus
    menalaus
    Apr 25, 2003
    338
    sleepy hollow
    +6
    and eltax are?.... sorry but if your going to knock someones system look at you own first.
    pgarbel, welcome to the forums, what will your new system be used for mainly? music or movies or both?
  6. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,190
    Weardale
    +57
    ooohh!:(
    can I get you a bowl of milk..? :rolleyes:
  7. pgarbe1
    pgarbe1
    I'd be looking to use the new system for music but if a suitable option existed for TV/Movie upgrade then I would give it some serious consideration.
  8. Hawklord
    Hawklord
    Feb 15, 2003
    3,432
    Aldershot, Hampshire
    +260
    What budget are we looking at max?
    For a completely new system for music and movies you could be looking at:-
    cd player, dvd/sacd/dvd-a player, integrated amp, av receiver , Front left & right, centre, surrounds and a subwoofer. For a half decent system that would be comparable with the B&o system would be greater than £2k imo.
  9. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +10
