Bigger Hard Disk in Sky+ Box
Discussion in 'Sky Digital TV Forum' started by Jeb, Dec 12, 2002.
  1. Jeb
    Jeb
    Nov 6, 2002
    65
    Staines
    Has anyone out there got any experience doing this?
    I beleive the standard unit has a 40GB Drive in it, if I replace it with a 120GB will I get 3 time as much recording space ?
    Jeb
  2. Xeonic
    Xeonic
    Yes this is possible, do a search on this because the subject came up a few times in the past. I've not done the procedure myself, but in summary the downsides seem to be :
    -invalidation of warranty, if that's a concern
    -"incorrect % free" indicator, possibly indicating firmware is looking for a 40Gb disk only
    - only specific disks working reliably over the long term
    - ventilation issues due to disk heat generation
    - limit on maximum usable space (around 100Gb) again probably a firmware thing
    The main thing I don't like the the idea of having so much stuff on a single drive which cannot easily be backed up - 40Gb is bad enough! - a digital connection to a PC would be nice :)
  3. AV Junky
    AV Junky
    Oct 30, 2002
    1,215
    Staffordshire, UK
    +69
    Let's face it, never in a million years! You and I both know that the term "back-up" has a very loose interpretation to some individuals. You know the ones - watch TV in their cabins with their parrot sitting on their shoulder, working out how many 'pieces of eight' they'll get for 'lending' out their 'back-up' copy of a film to their matey down the pub ;)
  4. rhinoman
    rhinoman
    Oct 31, 2000
    2,667
    71
    Herne Bay, Kent
    +41
    I've had a 120gb 7200 fbd drive from ebuyer running happily for a few weeks now, installation is no big deal just shove it in and it sorts itself out.
  5. Jeb
    Jeb
    Nov 6, 2002
    65
    Staines
    OK I've read all the other threads been to the Hummer web site (whats that all about ?) and I'm still left with one question.
    If I put my old Hard Disk back in can I watch the programmes on it again or will it be reformatted?
    Jeb
