big speakers, not so big room
Discussion in 'Home Cinema Speakers' started by mr_wriggly, Aug 14, 2001.
  1. mr_wriggly
    mr_wriggly
    I'm thinking of buying the Mission Cinema 70 surround speaker package from Richer Sounds (702e floor-standing front speakers, 70DS and 70C1 centre and rears) , to go with my fledgling Home cinema system.
    However, my room is small (in home cinema terms) at only 3.5*3.5 metres. So I'm worried these large speakers will swamp the room and make my movies sound dreadful.
    What does anyone reckon? Are there any better options for under £350?
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    For the price they are probably the best option. The 702e's shouldn't be too big for your room, and if they sound a little boomy you could try plugging their bass ports.
  3. Lowrider
    Lowrider
    You will be much better off with small speakers all around + a good subwoofer, and large speakers on any room are more difficult to position, now smallish and square... good luck...
