Big Speaker for large hall (portable)
surfymark
Hi Guys,
we often travel and perform in a hall holding maybe 100 children. For this we output music from an iPad (outputting picture to a projector also).
Recently we have been going abroad (flying) so I am looking for an amplified solution that outputs big, loud sound (the children can be very loud!) but that also is portable in some way. It doesn't need to be wireless, power is not a problem. It is the size and weight that I am more worried about.
Can you get speakers that fold up in some way? Or collapse?
What are your thoughts on this?
Many thanks
Mark
sounddog
Take a look at Portable PA Systems | Gear4music for some options...
The pro-audio arena is where you are likely to find your solution; your local Yellow Pages (does anyone still use that) or Google is likely to find you a local pro-audio shop where you can view some options. Failing that Maplins (if you are in the UK).
scoootyj
hello! agree with the reply from sounddog - a portable pa solution would seem to suit you far more than a domestic appliance for many reasons - not sure of your budget etc and how 'portable' ... is this too expensive?
HK Audio Lucas Nano 300 Portable PA System | Dawsons Music
have a read and see if its the kind of thing you are afer - they sound remarkable and at 10kg are very light! the satellites (small speakers) fit into the sub (bass speaker) and can even be set up on top of the sub for a very compact set up without having to carry stands, but unlike some '1 speaker' options, you have the opportunity for a full compact pa with a real stereo set-up! it also has the mixer built in - just check it has enough inputs for your needs! any other info let me know :0)
