BIG Quandry! Fuji P50XHA40 vs P55XHA40
Which one would you get!!
  • Total voters
    12
B
boff
Hi Guys
I am stuck!!! just looking for opinions etc!!
I currently have a fuji P50XHA10, which I want to upgrade for HDMI etc.
My 10 series has the same 3000:1 Pana panel as the new 40 series. The differences as I can see are the AVM2 (well worth it) and the larger amount of sockets including the HDMI input.
The P55 only has 900:1 panel, but it's fujitsus new trick eALIS panel, which apparently unlike the old ALIS panel, drives all the rows at the same time, no flicker! and the black whilst not zero black like the 50 is different because the grey scale capabilities of the 55 eALIS are better.
I've not found a shop with them next to each other so it's hard to compare. Also my current screen in un-callibrated (just using FINE mode) so I'm used to standard images.
Do I buy the new 40 series 50" - an improvement on mine with the AVMII etc? Or do I take a risk on the larger 55" which when ISF callibrated will possibly walk all over what I had (if you get me) and be that all important 5" bigger (I'd love the 63"!!)
Looking frowards to your feedback
cheers
boffster
MAW
Not so, the XHA10 is 5 series glass, 40 is a noticeable improvement.
Not so, e-alis is 1 driver for 2 pixels. I thought as you did for several years, but have very recently found out, thanks Camorra, that the poor contrast/grey blacks issue is precicely because it is JUST like previous ALIS, lights lines alternately, 60Hz fixed internal refresh rate, so is likely to be radically different to live with than your 10 series.
MAW
An aside to this thread I guess, but have you ever worked with a 55", can you input native res? Don't suppose there'd be much advantage in doing it at 50Hz, given the internal limitations.
Gordon @ Convergent AV
AVForums Sponsor
Not worked with the Fuji55.....I've seen it a few times. Piers had a go calibrating the one we had for Scottish HiFi show. I didn't think it was same league as the 50us40 thing.....it's nice...but for me the obviously brighter black level was too great. I'd rather loose some size and get a more dynamic image....but please don't think I think the thing is rubbish...it's not.
Gordon
D
dilsher
My obvious biased vote went to the 50" - but i do know some people love the extra few inches..... :devil:
D
dilsher
Oh and whilst I am at it..my eternal grateful thanks to HD, MAW and Gordy for blessing me with their brilliance and expertise..The screen just looks better every time i look at it Gordy! The textures, colour palette and sheer detail on offer on Kingdom of Heaven is breathtaking. And as for FRC - I hardly notice it on DVD!!!!
Those calibrated settings are wondrous, and I still have not seen HD proper on it yet!!!
You will be required back to do the recalibration once I get into DVD HD and SKY HD Gordy man! Fook.. I might even get it calibrated every year!
:thumbsup
Bless ya all.
xxx
madshi
Gordon @ Convergent AV said:
I'd go for the 50" 40us model and an off board video processor myself.....
Could you please elaborate in what way the 50" Fujitsu is better than the 50" Panasonic, when you use an external video processor? I mean I always thought the main (or even only) thing the Fujitsu was better in was the internal video electronics. So when you use an external video processor, anway, shouldn't the Panasonic be equal to the Fujitsu in that specific situation?
Thank you!
D
dilsher
..and Madshi mate? Where on earth does this thread have anything to do about a Panny???
madshi
Would you please point out where I have said that the Fujitsu is better than the Panasonic? My comments were about the relative merits of Fujitsu 50" and 55" models.
Sorry, mea culpa!
There's another thread currently running somewhere which is about Fujitsu vs. Pany. I guess I confused the threads...
:oops:
Stephen Wilde
If the choice is between 50" and 55" Fujitsu you should bear in mind the proposed viewing distance. Both have the same number of pixels so you can sit closer to the 50" without seeing the screendoor/chicken wire effect.
B
boff
Wowzers thanks for all the responses.
Is the 55" that bad? - Gordon could you get it to work with your trick ISF stuff? I suppose I'm sat about 2-3m away.
Has anyone seen them together -and if Alis is the same as e-Alis - where's the e come from.
I'd love the 55" to be as good, otherwise I wouldn;t be here I suppose - just need to understand how much difference I'll notice!
Thanks ppl
Boffster
D
dilsher
Ugly one:
Unfortunately, I have no fookin choice and have to sleep with the fookin beast along with my partner - as she prefers the bigger size... .
:rolleyes:
Piers
As the guy who set up the 2 Fujis at the Scottish Hi Fi show I think I am qualified to reply. The 50 was significantly better than the 55, even after recalibrating the 55 after the first day of the show. Both screens responded well to ISF calibration and most folk who saw them were oohing and aaahing over them both. The really critical viewers preferred the 50 but I wouldn't be unhappy with a 55 here.
GrahamMG
And as I was the guy who bolted both the 50 and 55 up at the Manchester show and ran demo's on them all weekend, they can both look utterly stunning with all material I threw at them from off air recordings,DVD, 720P and 1080i material. Some time spent on ISF calibration will only give even better results.
Oh and anyone that says that e-ALiS is anything like the old ALiS is misinformed, they are so very different in operation that any supposed similarity is quite wrong.
One thing is for sure the 55" is quite a bit bigger than the 50", far more so than people had imagined, everyone thought the 50 was a 42" screen next to the 55". Oh and sitting 8ft away is just fine as that is where we had the bench seating placed all last weekend. The 50" panel does indeed have a slightly deeper black but the detail within the black on either screen is far better than many had imagined with one scene from Batman begins showing that one chaps trousers were in fact brown in the darker areas when other screen manufacturers processing simply made them black which they simply wasn't......
Don't get completely carried away with ultimate black level, detail has to be considered here also as throwing away detail and turning off the pixel isn't always best.....
Oh and BTW, we will have the 50" and 63" at Hammersmith (and the 1080p projector running timed demo's) and the 50/55 and 63 can be run pixel for pixel without issue from a suitable HTPC, try that with a certain other manufacturer's screen.....
J
JetJockey
Hammersmith??
Is this the Novotel show thingy at London over the next few days?? :confused:
Regards, Gerald.
GrahamMG
Yep, What hi-fi S&V show,BTW nothing wrong with your screen, must be something else mate..
madshi
Thanks for the information! Very interesting for me, since I'm still thinking about what screen size to go for my 8ft viewing distance!
May I ask:
(1) Was this with 1360x768 or 1366x768? I thought the Fujitsus only supported 1360x768 with 1:1 pixel mapping?
(2) At which refresh rates can the Fujitsus do 1:1 pixel mapping? Both in 50Hz and 60Hz? What about 24/48 or 72Hz? Any of that working? The Panasonic commercial models can sync at 48Hz, as far as I've read.
(3) Did you get 1:1 pixel mapping via DVI or analog?
Thanks very much! :thumbsup:
madshi
In what way was the 50 better? Just in black level or also in other areas? Thank you!
MAW
Hi Graham, I'm the one who is misinformed, by Hitachi's website, a link posted by Camorra, who's erudite and informed postings we have all come to love :devil: If you have light to shed on E-ALIS please do, especially if I am misinformed. I hate that.
D
dilsher
ahhh..I do love it when the true experts on here and give us a proper "headline"!
Now what was that "other " screen I wonder???...lol!
:smashin:
J
JetJockey
Blimey
Thats a quick test.
Strange that the "other problem" never showed up before in 3 yrs of viewing. Signals are now being fed to a temporary display with no probs.
Regards.
They
I hope this might help. Culled from a thread I participated in back in April.
(edited and abridged)
Anyway, a few facts. ALiS is interlaced, a 42" PDP has 1024 x 1024 resolution but lights each 1024 x 512 alternately, so 512 horizontal lines all lit in the same instant (not scanned like a CRT) followed by the next 512 lines. There are (were) advantages to this PDP system but those advantages have been eroded by improvements in the quality/price/efficacy ratios with competing PDP technologies.
Nearly evey scaling technique requires a progressive frame, so a de-interlacer will be required to handle interlaced video and scale it to the panel resolution e.g. 1024 x 1024 but in the ALiS case the panel will be lit in an interlaced fashion. The ALiS panel could display a interlaced signal without de-interlacing and scaling first but how many 1024i video sources do we know of? It could take a 1080i signal and cull the 56 lines!
As for e-ALiS, it bares very little resemblance to ALiS (therefore e-ALiS is a very poor choice of name for this type of PDP). e-ALiS is an enclosed pixel progressive display. It addresses the sub-pixel cells in an interlaced fashion (not like ALiS and not like CRT) but lights all pixels in the same instant. e-ALiS is a very good PDP technology and hopefully Hitachi will succeed in making smaller panel versions soon and ditch ALiS altogether.
Cheers.
David Perry
MAW
That's what I thought before being 'enlightened' by another member who professes frequently to know about alis. I'll find the link to Hitachi.....
NonPayingMember
Previously Liam @ Prog AV
I quite liked the 55" when I first saw it. I walked up to it wanting to hate it and any resemblance to ALIS it bore, but prejudices aside it is actually a very good, very big plasma. But, it still doesn't have the dynamics of the 50" which for the videophile will have to be the better option. I've done one 55" for a chap who simply wanted bigger, but still very good, and he is still incredibly happy with it. It runs from a direct Sky and DVD feed, looks gorgeous on his wall, and is frickin' huge. But for the guy who in the same week asked me which is the ultimate for picture quality, I had to tell him to go for the 50".
On the panny vs fuji debate. I look at it a bit the same as I do with LCD projectors all being based on Epson D5 panels. By the same logic the Pana, Sanyo, Hitachi and Epson projectors should all be the same with a video processor - but they aren't. There isn't much in it with Fuji and Panasonic plasma, but I reckon enough. For one thing I still haven't had a Fujitsu 40 go wrong, and if it did I would much prefer dealing with Fuji than Pana, and I have a 3 year warranty to fall back on! I think the picture is a brighter too, we now have a 50XTS40GS (think that's the right code!) here and the more I look at it the more I am sure it is like a Panasonic in contrast, but brighter. A bit like the old 4-series SD Panasonic looks brighter (and better) than any SD panel since. Driven natively from a processor I doubt there are any differences in detail, depth, sharpness etc as this is all down to the processor. But if you are running a 720p option for 50Hz (which I often do) the Fujitsu handles it better than the Pana in my opinion. Plus I absolutely love the media box on the XTS (who ever thought I would be uttering those words!!!). 3 RGB scart, 2 component, HDMI, and two assignable optical digital inputs! Run everything to the media box, and one optical audio to the av amp (analogue audio is converted to digi). Easy peasy.
Trending threads
Latest news
T+A expands E-Series with PA 1100E integrated amplifier
  • By Andy Bassett
  • Published
Bowers & Wilkins unveils new PX wireless ANC headphones
  • By Andy Bassett
  • Published
Roku Premiere streaming device with 4K HDR hits UK
  • By Andy Bassett
  • Published
CTA launches 8K UHD TV display certification programme
  • By Andy Bassett
  • Published
Huawei launches Google-less Mate 30 and Mate 30 Pro phones
  • By Andy Bassett
  • Published
