big problems with ae300
Discussion in 'Projectors, Screens & Video Processors' started by PIPO, May 5, 2003.
  1. PIPO
    PIPO
    Oct 8, 2001
    portugal
    :mad:
    my ae300 has a problem.
    The video signal inputs on the "video in"
    The DVD is connected on "svideo".
    I see dvd with no problems.
    The TV is the probelm. when i select "video auto" to watch
    tv i see an image very distorced, like rain and the image cannot stay still.
    i think The problem is on the "video in" input on the AE300
    Help in resolving this problem, because i have the Japanese model
    and
    i dont have more connections to input the video signal.
    Can i make myself clear.
    :confused:
  2. WebLoader
    WebLoader
    i dont have an ae300 but do you have it set to the correct video system (eg Pal / NTSC ), that might be what is causing the problem?
  3. Mike
    Mike
    Ok I am running a AE300 both at comp video and S-Video all working 100% on the 300 you can select "auto 1" and "auto 2 "
    have you tried both ??
    Also have you scrolled through the options eg PAL, NTSC, etc
    Is the Japanese version multi system or for the local market only ( NTSC ) ??
    If S-video is working 100% comp video should also be working fine
  4. petrolhead
    petrolhead
    Mar 29, 2002
    4,788
    87
    Newcastle
    +116
    Sound very like your trying to push Pal into a NTSC setting.
    The player may be ok because its converting Pal to NTSC
  5. PIPO
    PIPO
    Oct 8, 2001
    portugal
    :confused:
    how can i change my pj to pal system.
    isn´t that automatic.
    inicially i saw TV in perfect conditions.
    sudenly (after put in on a celing mount) it went bad.
    if it is a ntsc/pal setting problem i should be able to fix it, or not. how? :eek: :mad:
