Big Brother is here! Your every online step will be monitored by your government!
I
ice-angel
Legislation is being prepared and forwarded by european governments as we speak to insure that every online step each individual user takes, every address he visits, every email he sends or receives, every action, every data transfer whatsoever from the moment a modem is turned on and connected to the net, will be logged and maintained in a database, directly accessed and monitored by governments and their employees.
The question is, will you sit idle and let that happen ?
http://www.dataretentionisnosolution.com
Don't let your passiveness allow the accelerated transformation of the world as we know it into an Orwellian nightmare where such concepts as personal privacy, individual rights and freedom of speech will be nothing more than a remote dream.
Do your part - please sign today. Inform all your friends.
Miyazaki
I signed it. No idea what difference it will make though?! :confused:
The Dude
I've heard using 'Google-earth CIA' they can watch everything we all do as well, they even know what you're dreaming about from reading your eye movements as you sleep...!!! :eek:
( Obviously satellites cannot do this, which is why lightbulbs have tiny cameras inside them which only activate when it is dark. )
:lesson: :lesson:
You think you are lighting up a room, when you are actually supplying electricity to charge the batteries of the spy-cams!
Then, when the hard-drive is full and the device needs returning to base, they simply 'blow the bulb' by sending a mains-spike to that socket in your house.
We, being the innocent fools that we are, replace the spy-bulb with another identical one :rolleyes:, and toss the 'broken' bulb in the rubbish, where it can be easily collected by 'refuse operatives' who actually work for the government ( they are known in govt. circles as 'the bin-men' )
:lesson::lesson:
This info is all collected, recorded, collated, and fed wirelesly via GSM to GWB's Nokia 6630.... he can order a 'hit' on you the very minute you speak out against the establishment.. :nono:
overkill
Dude, keep that tinfoil wrapped tight buddy. They can see and hear everything you know..............
Solomon Grundy
This could be a trick by the New World Order...you sign this, they know who you are, a petition signing troublemaker, and when the "revolution" comes guess who's door they'll be knocking on first...no way I'll sign this. Anyway, I've got to go and finish making my new tin foil hat...
The Dude
In case you're wondering why I'm being so flippant about this, it's because as always, I'm already one step ahead of the game :thumbsup:
Overkill, Decadence: It's actually SILVER foil you need to use... don't be fooled into thinking that common tinfoil will offer you any decent protection :nono:
That's just what they want you to think... ;)
I
ice-angel
Rats, you found me. Oh well, on with the plan to plant microscopic surveillance devices in bread slices :(
overkill
Rats! :mad: That means I wrapped all the inside of my hats, coats, underpants, and the outside of all PC equipment with tinfoil for nothing.............
:D
pjclark1
You forgot the most vital bit
the foil only works if you crinkle it up first, smooth foil is useless!
Steven
Senior Moderator
Here's an idea.....why not only moniter known sites used by potential/actual terrorists.....
Or maybe they wanna find out how many are anti-Blair's are on forums.....well there ain't enough jail cells for us all!
Governments though don't do things the simple straight forward way. They'd be damned if they spend the public's money wisely
S
shadowritten
I thought IP addresses could be ghosted, click trails covered, email addresses faked and email content encryped? What, exactly, will governments be tracing if such measures are taken?
Besides, most email and Net traffic is so completely banal - and there's so much of it - that it would be either useless or take some VERY sophisticated software to make it useable. And even then, I say: 'For what?' If you're a terrorist, you deserve to be caught out. Ditto, if you're sleeping with my missus!!!
I
ice-angel
Plug in a nice dose of IP spoofing or simply a good trojan, and you have the answer: innocent bystanders who happened to have their PC in the wrong place at the wrong time.
samjet
there are plenty of free encryption algorithms that can be downloaded - i'm told ;)
that even the NSA cannot break :D
they may know you've sent an email but cannot read it!
Miyazaki
so all the regular joes will be **** on, but all the hardened criminals will still get away with everything. Nice to know that times are changing eh?! :rolleyes:
overkill
There are plenty of 'ghosting' packages around that allow you to beat the average watcher, but, as EG will tell you, it's difficult to truly hide your IP address.
mjn
And just where are they going to store all this information? Thats quite a bit of information....
Ed Selley
AVF Reviewer
Couple of zip drives should do the trick.
Solomon Grundy
If they intercept phone calls based on key words they might end up arresting loads of gays thinking they said "I am going to bomb you"
...just a thought...
pringtef
ROFLMAO!!! :rotfl:
I
ice-angel
The problem with having encryption around which the government can't break is that sooner or later they'll want to make it illegal to use encryption which they can't break.
We... will.. stick... our... nose... up... your... asses... slaves.
S
shadowritten
As hackers who've infiltrated the Pentagon know, if a software system can be built, it can be destroyed - or at least, bypassed.
When will those in authority wake up and realise that impermanence is a fact of life?
Peridot
:lesson: :lesson:
:lesson::lesson:
:rotfl: :rotfl: :rotfl: :clap:
I knew we wwere doomed when we stopped using candles :D
KoThreads
You people are so daft. Tin foil on your head, PC etc. Why?
I've done the sensible thing. spent yesterday covering my whole house thus saving time. Everythings covered, great insulation, and as the sun reflects off it I burn down every house around me so no neighbours to spy on me, sorted.
Trending threads
Latest news
T+A expands E-Series with PA 1100E integrated amplifier
  • By Andy Bassett
  • Published
Bowers & Wilkins unveils new PX wireless ANC headphones
  • By Andy Bassett
  • Published
Roku Premiere streaming device with 4K HDR hits UK
  • By Andy Bassett
  • Published
CTA launches 8K UHD TV display certification programme
  • By Andy Bassett
  • Published
Huawei launches Google-less Mate 30 and Mate 30 Pro phones
  • By Andy Bassett
  • Published
Latest threads
