Bibooo & the toshiba **ZD26P
Discussion in 'General TV Discussions Forum' started by [email protected]!, Jan 25, 2004.
  1. wh@ssup!
    [email protected]!
    Bibooo, I was wondering if you have a tv in the above range. If so I was wondering if you could post your settings for the wide mode/setting for best compromise. My picture is nigh on level but the geometry is still way off. I don't know if screen size affects the settings, mine is a 28 inch model.
    If this is not possible, cheers anyway for your other excellent posts on this range.
    [email protected]!
  2. bibooo
    bibooo
    Aug 15, 2002
    227
    Earth
    +11
    [email protected]!
    Unfortunately posting my service menu settings will not do you any good as these will vary from set to set (even if they were the same size tube).
    Persevere with changing the relevant parameters until you are happy with the results; just remember you will never get it 100% perfect. I hope my guide can give you an idea of which settings to change and what you should be aiming for.
    Good luck.
    bibooo
