Biamping the AVR600?
Discussion in 'AV Receivers & Amplifiers' started by Sab, Mar 7, 2013.
Tags:
  1. Sab
    Sab
    Dec 18, 2002
    771
    London
    +26
    How do I biamp the front left and right speakers with the AVR600 in a 5.1 system?
  2. Damian1978
    Damian1978
    Jul 15, 2000
    4,519
    107
    Fleetwood, Lancashire
    +262
    Easy! Use the 6+7 Left and Right back surround channel speaker outs and change the settings in the menu to enable bi amp mode
  3. larkone
    larkone
    Apr 21, 2006
    4,269
    134
    North Essex
    +1,182
    And don't forget to remove the links between the speaker terminals first or it could get expensive. Apologies if you know this but worth mentioning just in case.
  4. Sab
    Sab
    Dec 18, 2002
    771
    London
    +26
    I have been biamping my P7 that is why I was not sure how to biamp the AVR600. It looks like the P7 will have to go back to Arcam for repair.
    Biamping the AVR600: is it just a case of connecting red to red and black to black in any order using the spare surround back channels?
  5. Damian1978
    Damian1978
    Jul 15, 2000
    4,519
    107
    +262
    Yeah. I use channels 1 & 2 for my woofers and 6 & 7 for tweeters but it shouldn't matter.
  6. DCX
    DCX
    Feb 21, 2013
    2
    Actually, it does matter - the manual states that when bi amp mode is selected, the LF signal is passed from channels 1&2, and the HF signal is passed from channels 6&7. Ironically, your current config is correct, but I just thought I'd clarify. BTW, I'm an AVR400 owner, but I'd assume the manual sections are the same for both models. Cheers...
  7. larkone
    larkone
    Apr 21, 2006
    4,269
    134
    North Essex
    +1,182
    In bi-amp mode the same L+R signal is output to channels 6&7 as channels 1&2. No filtering takes place, that happens in the speaker crossover. The 600 manual does not state which way round they should connect. The reality is it makes no difference, I think the 400 manual is just trying to be more helpful.
  8. Wag
    Wag
    Mar 10, 2009
    585
    28
    Kent
    +58
    This is what my AVR600 manual says. Nothing about which amp should be used for which drivers...unless I've missed it somewhere....
    Use Channels 6+7 for – If your main zone speaker
    set up does not include Surround Back Left and Right speakers, you can choose to use the Surround Back amplifier channels to bi-amp the Front Left and Right pair, or as a stereo power amplifier for Zone 2 (but note that powered Zone 2 is not available on the AV888).
