Bi wiring
Discussion in 'Home Cinema Speakers' started by syndrome69, Aug 1, 2005.
  1. syndrome69
    syndrome69
    Can someone please give me a low-down on biwiring.
    Currently i have a marantz pm7000 amp and B&W 602 s3 speakers. Will bi-wiring increase sound quality enough for an amateur hi-fi person like me to notice the difference? Will power be increased? Will i need to put the volume as high as i would if it weren't bi-wired?
    Sorry for all the questions.. just curious and trying to get the best sound possible from my setup
    cheers
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    There are many, many threads on the forum already discussing this which you should try and read.
    My own take is that you won't notice a difference. Power certainly won't be increased, nor will there be a volume difference. It may be worth swapping the metal jumper bars with short lengths of your speaker cable though. :)
  3. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    I think one of the principle arguments is over inductance and the magnetic fields of the bass interfering with the treble (or visa versa). I guess this can be substantiated by ocilliscopes and stuff....how good are your ears? How good is yor equiplent and cable?
  4. Troon
    Troon
    Apr 28, 2005
    151
    I wouldn't put money on it. I'm not aware of any scientific evidence of biwiring having any beneficial effect over a single length of cable with equivalent cross-sectional area and resistance.
    If anyone knows of one (not sponsored by M*****r), I'd love to hear about it.
  5. narcoticsuite
    narcoticsuite
    Jul 7, 2005
    83
    In my experience it makes absolutely no difference and i can't really see how it could do.
    As mentioned by eviljohn I would replace the jumper bars with short lengths of cable.
  6. syndrome69
    syndrome69
    thanks for info..
    my ears are fine ... but if it's going to make a tiny difference then i wont bother. Most of the time I'm playing MP3's via my computer, so I assume the only time i might notice a difference would be if i was using a high quality cd player with expensive interconnects. I think i'll just upgrade to a more powerful amp- How do you guys rate the NAD C370?
