bi wiring speakers? how?
Gary D
i have a Yamaha DSP-AX620 and a set of Eltax liberty speakers can anyone shed any light on how to bi wire the front speakers?
do i use speaker set A to one set of speaker posts and set B to the other?
do i need a bi wire cable? can i use two runs of speaker cable to do this?
is it worth it?
any help would be welcome.
thanks
Gary
G
Gomez
Originally posted by buns
In my view and in that of many others, it is a total waste of time.
ad
And of cable, which can be much more expensive. ;)
Gary D
thanks guys, i wont bother then, i'll spend the time on watching a dvd i'll buy with the money that would have spent on new cable
cheers
gary
buns
If you are in any way a handy man type of guy, make your own cable since it is much cheaper.
ad
Nic Rhodes
Originally posted by Garyd
thanks guys, i wont bother then, i'll spend the time on watching a dvd i'll buy with the cable i would have bought.
Much better idea. Buy wiring :mad:
buns
Lol :D enjoy it all and dont worry! Wish i could follow that advice, i seem to enjoy the fiddling!
ad
eviljohn2
Although I havn't tried it myself, a few threads here on the subject seem to conclude that rather than biwiring, your best bet is to replace the little metal conductors you get supplied with your speakers to connect the terminals with a length of your speaker cable.
If you can find a few spare centimetres of cable it shouldn't be too hard to do and is a lot cheaper than "proper" biwiring!
buns
Bingo!
The term 'proper' biwiring is something of a misleading phrase since biwiring is only proper to those selling the cables! :D
ad
Samsung S95B QD OLED Review - A Quantum Leap for OLED!
