Bi-Wiring - Speaker A + B
Discussion in 'AV Receivers & Amplifiers' started by guyb, Jun 2, 2003.
  1. guyb
    guyb
    May 20, 2001
    642
    Leamington Spa
    +5
    Hi All
    I have a question about bi-wiring. I have heard that it is possible to bi-wire your front speakers by connecting the front speakers to both Speaker A and Speaker B terminals of an AV receiver (such as Marantz SR7300) - is this possible and if so can someone tell me how to do it (i.e. which cables plug into which speaker terminals)
    Guy
  2. Montana
    Montana
    May 24, 2003
    194
    Crawley , West Sussex , England
    Hi Guyb,
    Reading this post and being a newbie here, I was surprised that I might be able to help.I have one question for you first though.Can you have both your A and B speakers on at the same time ?
    If you can then first of all take the bridges off the terminals on the back of the speakers.Next there should be some markings saying which set of terminals are HF and LF(High Frequency and Low Frequency)on the speaker terminals, run one pair of speaker cables to the HF termainls and connect them to speaker set A on your AV amp/rec and then run another pair speaker cables from the LF connectors to speaker set B on your AMP, then repeat this for your other speaker.
    Just as aside note dont on one speaker run the HF to speaker A terminals and then on the other run the HF to speaker B terminals, seems to sound a little strange, it shouldn't but it seems to on mine, just keeps things the same.
    I tried this out myself which an older rvx520 receiver and Eltax speakers and the difference was really noticable, so good luck with that , and let us all know how you get on.Plus as a suggestion always use decent banana plugs as it will make your life easier changing terminals over(well it did with me anyway) and you get a better connection.
    I going to stop rabbiting on now so let us know , and post back, if I have made it to confusing, or you you need any more pointers.
    Andy
  3. guyb
    guyb
    May 20, 2001
    642
    Leamington Spa
    +5
    Thanks for the response. Yes, you can have both speaker A and speaker B on at the same time. As soon as I get some speaker cable I will try it out. I'll let you know how I get on.
    Guy
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,506
    2
    71
    High Wycombe, Bucks, UK
    +59
    You need only connect to either the A or B terminals, you don't need to use both.
    The only end you need split ends is at the speakers end.
  5. Montana
    Montana
    May 24, 2003
    194
    Thanks Retro,
    I forgot that you can put all both sets of positive and negative together into the speaker set A, thus giving you the added advantage of having another setup if you require.Also there has been some talk about, that if you use BOTH A and B speakers at the same time it affects your impedence, making your speakers harder to drive( I haven't found that the case with my setup), but maybe someone else with a greater knowledge than mine can clear up all the pros and cons of this, so I can learn as well.
    Andy
  6. wookie
    wookie
    Using A & B on most amps makes no difference to impedance.
    Electrically, the amp sees the same as a single run of cable going into 4 terminals (when the links are in place).
    Using A & B does normally provide twice the cable inside the amp though.
    Bi-Wiring is just two runs of cable in parallel (should, in theory have the resistance of half of a single cable run).
    Some amps connect speakers A in series with speakers B and this would effect the result as the tweeter would be connected in series with the mids/woofers.
