Bi-wiring query on rear-surround speakers
Discussion in 'Cables & Switches' started by MJeeves, Oct 28, 2004.
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    Hi Guys,
    I have recently purchased the Pioneer AX5AiS receiver and realised that it’s “Rear Surround” speaker terminals only has terminals for 1 set of left and right speaker cables. My “Rear Surround” speakers have TWO sets of speaker terminals on EACH speaker (one for bass and one for treble). How do I connect this up? Can both sets of speaker cables go into the same terminal on my receiver?
    Thanks.
  2. isko
    isko
    Aug 29, 2004
    26
    From positive terminal (+) of receiver goes two cables to the red terminal of speakers, and from negative terminal(-) of receiver goes two cables to the black terminals of speakers. This is one way of bi-wiring which is explained in my Yamaha speakers manual. Cables must be same quality and spec.
  3. Londondecca
    Londondecca
    Dec 21, 2003
    2,105
    +108
    I would question the benefits of bi-wiring rear speakers, front speakers - yes but if you have some spare cable it is an easy procedure.
