Bi-wiring query on rear-surround speakers
Discussion in 'Home Cinema Speakers' started by MJeeves, Oct 28, 2004.
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,054
    Crayford
    +224
    Hi Guys,
    I have recently purchased the Pioneer AX5AiS receiver and realised that it’s “Rear Surround” speaker terminals only has terminals for 1 set of left and right speaker cables. My “Rear Surround” speakers have TWO sets of speaker terminals on EACH speaker (one for bass and one for treble). How do I connect this up? Can both sets of speaker cables go into the same terminal on my receiver?
    Thanks.
  2. Jon
    Jon
    Yes you just double up the 2 positives and 2 negatives at the amp end, that will work fine!
    Jon
  3. Paulbmw
    Paulbmw
    I got a vsx-d814 and do it the same way as Jon suggests.Works for me.Look at richer sounds website,i think youll find a diagram explaining this subject :)
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Is it worthwhile though. There is much debate as to the validity of biwiring on front speakers ( I am neutral) but I cannot see it having any sonic benefit on rear speakers at all
  5. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I have a "theory": assuming you have a run of 1.5mm2 then bi-wiring with a 2nd run of identical 1.5mm2 cable would have the same effect as replacing the original cable with a 3mm2 cable (and leaving the metal bridges in place).
    That said bi-wiring the rears seems a bit OTT (over-the-top) to me. Just because the speakers offer this option it doesn't mean you have to use it - and some of the finest speakers made are not even designed for bi-wiring, which should make you ask why ... ;)
