Bi-wiring query on rear-surround speakers
Discussion in 'AV Receivers & Amplifiers' started by MJeeves, Oct 28, 2004.
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    Hi Guys,
    I have recently purchased the Pioneer AX5AiS receiver and realised that it’s “Rear Surround” speaker terminals only has terminals for 1 set of left and right speaker cables. My “Rear Surround” speakers have TWO sets of speaker terminals on EACH speaker (one for bass and one for treble). How do I connect this up? Can both sets of speaker cables go into the same terminal on my receiver?
    Thanks.
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Yes. But I wouldn't really bother. The rear surrounds aren't going to be worked too hard and will sound just fine with the jumpers in place IMO. Saves a lot of extra speaker wire too. ;)
  3. Hefner
    Hefner
    Sep 29, 2004
    52
    Leeds
    I would replace the sets of jumpers you have with some speaker cable.
    The jumpers usually aren't up to much and a simple thing such as replacing the jumpers with some cable will help with the sound quality.
