Bi-wiring my q acoustic 2020
Discussion in 'AV Receivers & Amplifiers' started by Hjm80, Mar 8, 2013.
  1. Hjm80
    Hjm80
    Oct 12, 2011
    167
    +7
    I have a onkyo A-5VL amp and a pair of q-acoustic 2020. Can I, and would it be worth biwiring the speakers from my amp. I'm not overly knowledgeable with regards to bi wiring.
  2. dante01
    dante01
    Mar 5, 2009
    45,864
    +10,963
    Bi-wiring is a pointless exercise unless used in conjunction with bi-amping. Bi-wtring on its own simply equates to doubling the thickness of the wire, which in itself can be more easily done by simply having a single run of thicker wire from the amp to the speakers. Bi-amping would allow for the tweeter and woofer drive units to have separate sources of power, supplied to them by separate runs of wire (bi-wire).
  3. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,438
    As above do not bother biwiring just get some single 2.5mm oxygen free copper cable and you will be fine.
